Maximun Cable Length for PIC to LCD
Results 1 to 40 of 53
    The background looks like a chair seat.
    DING! Give that man a cigar.
    I forgot to answer it. oops.
    I have never used MPASM. I should try and get it going
    Just go here... at the bottom of the page, install the MPLAB IDE v8.00 Full Release Zipped Installation
    http://www.microchip.com/stellent/id...&part=SW007002
    Are you using MicroCode Studio for the IDE?
    one of the less neat prototype i've never ever saw ...
    http://www.botmag.com/articles/bionic_stamp.shtml
    Ontario Canada
    Hi Darrel. I am using Microcode Studio.
    Great. That makes it easy.
    After installing MPLAB ...
    In MCS, go to the View | Compile and Program Options | Assembler Tab
    Click the Find Manually ... button and point it to
    C:\program files\microchip\mpasm suite
    Then check the Use MPASM checkbox.
    You should be good to go.
    OOPs, one more thing to get that to compile.
    In your PBP folder, open the 16F877A.INC file, and comment out the __config line with a semicolon ;
    Now you should be good to go.
    mister_e,
    At least now I know where to go if I need some extra wire.
    Sheesh.
    Ontario Canada
    Hi Darrel. I have installed MPLAB IDE v8.00 Full Release and setup was done as mentioned.
    Now when compiled I get the MPASM window showing the process and then shows 18 errors.
    This goes by very fast and starts green and then goes red. The errors are similar to what I had before. Here are a few. I have omitted the path for each error.
    205 : Found label after column 1. (WritePort)
    205 : Illegal opcode(_Char)
    234 : Illegal opcode(_LCD_DATAUS)
    249 : Found label after column 1.(DelayUS)
    267 : Illegal opcode(LCD_COMMANDUS)
    and many more
    Arrrrgh!
    Sorry to put you thru all this, it shouldn't be that hard.
    I can't really say what's happening from the errors you showed.
    I could probably see what's wrong if you could send the .LST file.
    It'll be too big to post, but you could email it to
    darrel at pbpgroup.com
    It should've worked
    mister_e,
    Sheesh.
    Have a look at the last lines of the link... About The Author.. i'm afraid
    And to think I did not have to go to school to be that messy
  1. 16f688 LCD what have I done wrong
    Last Post: - 8th August 2009, 20:54
  2. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  3. DS1820 Max Cable length ?
    By dccch in forum General
    Last Post: - 24th January 2008, 08:44
  4. Measure cable length with a PIC?
    Last Post: - 15th July 2007, 19:45
  5. Need help with LCD number display.
