Hi Darrel!
How long is that flat cable on the second LCD? It seems really long!
Hi Darrel!
That's impressive! About 8,5 meters! Lets see what wildbilly will do on the 40ft.
Great code Darrel.
Merry Christmas to all and a happy new year. Hi Darrel. I have not been able to do much since you gave me the "Hex". Remember those two fingers? OK, seriously your code works flawlessly. I have been able to run both LCD's on 40ft of cable. Thanks very much for your time and code. I learned a lot this year from this forum, thanks to all especially Darrel.
Hopefully much more projects in the new year.
That's Great wildbilly.
And Happy New Year to you too.
I was hoping it would go the 40ft. but wasn't sure.
Don't want to ruin it for you if you're still trying to do 3 LCD's, but I can show you how, if you give up.
regards,
Hi Darrel. I would like to know how to do 3 LCD's. I won't turn down a chance of learning more. Thanks
OK, let's go with the learning ... idea ...
Here's the changes to add 1 more display to what we already have.
Mostly, it's just "more of the same".
These are the same 3 sections that were modified the last time.
New changes are in red ...
Main ProgramLCD_AnyPin.pbpCode:;----[ Change these to match your LCD ]--------------------------------------- LCD_DB4 VAR PORTB.0 LCD_DB5 VAR PORTB.1 LCD_DB6 VAR PORTB.2 LCD_DB7 VAR PORTB.3 LCD_RS VAR PORTB.4 LCD_E1 VAR PORTB.5 LCD_E2 VAR PORTB.6 LCD_E3 VAR PORTD.0 LCDEN VAR BYTE BANK0 ; Enable bits for each LCD LCD1EN VAR LCDEN.0 LCD2EN VAR LCDEN.1 LCD3EN VAR LCDEN.2 LCD_Lines CON 2 ; # of Lines on LCD, 1 or 2 (Note: use 2 for 4 lines) LCD_DATAUS CON 50 ; Data delay time in us LCD_COMMANDUS CON 2000 ; Command delay time in us INCLUDE "LCD_AnyPin.pbp" ; *** Include MUST be AFTER LCD Pin assignments **** LOW LCD_E1 ; Start with Enables OUTPUT LOW LOW LCD_E2 LOW LCD_E3
Code:ASM LCD_Port_HNIB macro ; Port definition for LCD High Nibble Vbit LCDCDFLAG, _LCD_RS ; Select Command/Data register DelayUS 2 NOP Vpin 4, _LCD_DB4 ; Put the High Nibble on the bus Vpin 5, _LCD_DB5 Vpin 6, _LCD_DB6 Vpin 7, _LCD_DB7 DelayUS 2 btfsc _LCD1EN ; Set enable(s) High bsf _LCD_E1 btfsc _LCD2EN bsf _LCD_E2 btfsc _LCD3EN bsf _LCD_E3 DelayUS 5 ; hold for 5us bcf _LCD_E1 ; Enable(s) Low - Clocks data bcf _LCD_E2 bcf _LCD_E3 endm ;----------------------- LCD_Port_LNIB macro ; Port definition for LCD Low Nibble Vpin 0, _LCD_DB4 ; Put the Low Nibble on the bus Vpin 1, _LCD_DB5 Vpin 2, _LCD_DB6 Vpin 3, _LCD_DB7 DelayUS 2 btfsc _LCD1EN ; Set enable(s) High bsf _LCD_E1 btfsc _LCD2EN bsf _LCD_E2 btfsc _LCD3EN bsf _LCD_E3 DelayUS 5 ; hold for 5us bcf _LCD_E1 ; Enable(s) Low - Clocks data bcf _LCD_E2 bcf _LCD_E3 endm ENDASM
LCD_AnyPin.pbp
And then, to use it.Code:;----[Initialize the LCD]-------------------(DO NOT Change)------------------- LCD_Init: @ OutputPort LCD_Port_HNIB ; Set LCD bus to OUTPUT LCDEN = %111 ; Initialize all LCD's at the same time LOW LCD_RS ; Start with RS LOW Char = 3 : gosub LCDsendShortCOM : @ DelayUS 6000 gosub LCDsendShortCOM : @ DelayUS 1000 gosub LCDsendShortCOM : @ DelayUS 1000 Char = 2 : gosub LCDsendShortCOM : @ DelayUS 1000 ; Start 4-bit mode Char = $28 : gosub LCDsendCOM ; Function Set, 4-bit, 2-line, 5x7 Char = $0C : gosub LCDsendCOM ; Display ON Char = $01 : gosub LCDsendCOM ; Clear Screen Char = $06 : gosub LCDsendCOM ; Entry Mode LCD_Initialized = 1 ; LCD has been Initialized goto LCDAfterInit
It still works the same as before.
But now it's easier to treat the Enable bits like a binary number.
With each bit representing a different display ...
And that should be it.<hr>Code:LCDEN = %001 LCDOUT $FE,$80, "Display 1" LCDEN = %010 LCDOUT $FE,$80, "Display 2" LCDEN = %100 LCDOUT $FE,$80, "Display 3" LCDEN = %111 LCDOUT $FE,$C0, "ALL Displays"
Now, Even though this all works fine ...
I don't like it.
After making all the changes to get 3 LCD's to work.
It's still limited to 3 LCD's.
If you want 4, then you have to go modify it again.
Then if you want to use 2 LCD's on another project. It'll throw a bunch of errors, that won't make sense 6 months from now.
Then there's the Timing options.
What if the cable is longer? Or shorter? How do you adjust the delays?
So what I've done, is create a new module that should incorporate everything learned here, and allow everyone to have up to 8 LCD's on long or short cables without to much hassle.
But it takes longer to post the thread, than it does to write the program.
And I Gotta work tomorrow too.
Feel free to use the code I just posted (it should work)
Or you may want to wait for my next post in the PBP Extensions forum. (day or two)<hr>
P.S. It's unfortunate that we still won't know the answer to your first question.
Uhhh, 40 ft, as far as we can say.Originally Posted by wildbilly
But who knows?
Question from the sidelines...maybe an idea...not sure...haven't looked into it yet...
Couldn't the LCDOUT command itself be 'hi-jacked' inside on of the macros to change the E line assignment dynamically? As far as I know, LCDs won't do squat unless the E line is pulsed.
Maybe something like:
LCDOUT $fe , $fe , 0 , "First LCD"
LCDOUT $fe , $fe , 1 , "Second LCD"
LCDOUT $fe , $fe , 2 , "Third LCD"
....and so on and so on...
As far as I know, there aren't any character LCDs any wider than 40 characters. If the second character in the 'string' was anything above $FC, it could be a 'hijack' command...
or something like that anyways...
As for myself, like I said before, I'm running 3 different types of LCDs on my OBD interface right now (16x2 parallel, 122x32 graphic mode, and a 130x130 Nokia color knockoff).
Guess which one is the easiest to interface with?![]()
Sure,Originally Posted by skimask
With complete control of the LCDOUT command, you can do pretty much whatever you want.
And, It's not a bad idea.
So, with the existing code from this thread.
Changing the LCDsend routine like this ...Then you can embed the LCD selection inside the LCDOUT statements...Code:;----[Send a byte to the Virtual LCD PORT]------------(DO NOT Change)--------- TempChar var byte Char VAR Byte LCD_Initialized VAR FLAGS.1 RSS VAR FLAGS.0 ; LCD RS State HJ_Command VAR BIT ;----[ This routine is called once for every character sent by LCDOUT ]------- LCDsend: @ MOVE?AB _TempChar ; Get char sent by LCDOUT, in WREG if !LCD_Initialized then LCD_Init ; Make sure LCD was Initialized LCDAfterInit: IF HJ_Command then LCDEN = TempChar : HJ_Command = 0 : goto LCDsendDone IF RSS then NO_HJcheck IF TempChar = $FE then RSS = 1 : HJ_Command = 1 : goto LCDsendDone NO_HJcheck: if TempChar = $FE then RSS=0 : goto LCDsendDone ; next char is Command Char = TempChar LCDsendCOM: @ WritePort _Char, LCD_Port_HNIB ; send the High Nibble LCDsendShortCOM: @ WritePort _Char, LCD_Port_LNIB ; send the Low Nibble IF RSS = 0 then ; Is a Command IF Char = 1 then CommandDelay ; Long delay for Clear Screen IF Char = 2 then CommandDelay ; Long delay for Home @ DelayUS _LCD_DATAUS ; Short delay for everything else goto DelayDone else @ DelayUS _LCD_DATAUS ; Short delay for Data goto DelayDone endif CommandDelay: @ DelayUS _LCD_COMMANDUS DelayDone: if LCD_Initialized then RSS = 1 ; Set RS to Data next time LCDsendDone: returnAnd it still works the original way too. (Choices)Code:LCDOUT $FE,$FE,%001, $FE,$80, "Display 1" LCDOUT $FE,$FE,%010, $FE,$80, "Display 2" LCDOUT $FE,$FE,%100, $FE,$80, "Display 3" LCDOUT $FE,$FE,%111, $FE,$C0, "ALL Displays"Now I really gotta go to bed.Code:LCDEN = %001 LCDOUT $FE,$80, "Display 1" LCDEN = %010 LCDOUT $FE,$80, "Display 2" LCDEN = %100 LCDOUT $FE,$80, "Display 3" LCDEN = %111 LCDOUT $FE,$C0, "ALL Displays"
Well, I don't exactly use LCDOUT for the GLCD, but I do the 'printstr' from awhile back to do the display with it, and I modified a version for the Nokia ('printstr2', original eh?), and I used that 'copystr' from awhile back, modified another couple of versions into 'printvar' and 'printvar2', defined a dedicated string, use it only with those macros, handle it outside of the printvar routines, and send it out when I want it, along with the x,y. Works for me...
I suppose it wouldn't be that hard, relatively speaking anyways, to hijack the lcdout command further...maybe a predefined types (i.e. DEFINE LCDTYPE $00 ; low nybble = lcd number, high nybble = lcd type, this case, first lcd, parallel, another case DEFINE LCDTYPE $11; low nybble = second lcd, high nybble = 122x32,SED1520 type, and so on...).
Great...more crap to do...
Question: How would one go about turning this sort of thing into a 'One Stop Shop' solution for extending PBP's capabilities? One that wouldn't involve modifying libraries, macro sets, or other files... A single include file or would this involve some sort of remaking the compiler itself? Those printstr and printvar macros I've got are all in-line with my normal code in all my programs. Yes, those could easily be done with a single 'include' file. But, would there be an easy way to add these 'extensions' by default? Not only for this LCD modification, but for the matrix keypad, SD card access, IDE access, '1820 reading, etc?
that would be really nice indeed... i think it's more a pre-compiler option, not sure how Melabs could give such compiler access... i know an automated solution, but, it's still instage.
Yeah, there's a lot of new things in MisterE land to come in 2008.
