Maximun Cable Length for PIC to LCD
Results 1 to 40 of 53
    Thumbs up
    Maybe you'll Dig this idea too.
    GLCD's using LCDOUT.
    Well, I don't exactly use LCDOUT for the GLCD, but I do the 'printstr' from awhile back to do the display with it, and I modified a version for the Nokia ('printstr2', original eh?), and I used that 'copystr' from awhile back, modified another couple of versions into 'printvar' and 'printvar2', defined a dedicated string, use it only with those macros, handle it outside of the printvar routines, and send it out when I want it, along with the x,y. Works for me...
    I suppose it wouldn't be that hard, relatively speaking anyways, to hijack the lcdout command further...maybe a predefined types (i.e. DEFINE LCDTYPE $00 ; low nybble = lcd number, high nybble = lcd type, this case, first lcd, parallel, another case DEFINE LCDTYPE $11; low nybble = second lcd, high nybble = 122x32,SED1520 type, and so on...).
    Great...more crap to do...
    Question: How would one go about turning this sort of thing into a 'One Stop Shop' solution for extending PBP's capabilities? One that wouldn't involve modifying libraries, macro sets, or other files... A single include file or would this involve some sort of remaking the compiler itself? Those printstr and printvar macros I've got are all in-line with my normal code in all my programs. Yes, those could easily be done with a single 'include' file. But, would there be an easy way to add these 'extensions' by default? Not only for this LCD modification, but for the matrix keypad, SD card access, IDE access, '1820 reading, etc?
    that would be really nice indeed... i think it's more a pre-compiler option, not sure how Melabs could give such compiler access... i know an automated solution, but, it's still in stage.
    Yeah, there's a lot of new things in MisterE land to come in 2008.
  1. 16f688 LCD what have I done wrong
  2. Play with LCD on PICDEM
  3. DS1820 Max Cable length ?
    By dccch in forum General
    Last Post: - 24th January 2008, 07:44
  4. Measure cable length with a PIC?
    Last Post: - 15th July 2007, 18:45
  5. Need help with LCD number display.
