Power line comms X-10
Results 1 to 16 of 16
Threaded View
  1. #6
    Dec 2005
    Might also be of use.
    Perhaps, but probably not in the case of Status Request. There are only a few X-10 modules that respond to Status Request and those do not actually reflect the state of the load - merely the state of the module. The lamp might be burned out, turned off at its switch or unplugged but the module will still report its ON if that's the state of the module. It's more a, "What's your best guess of status?" request and a, "Your guess is as good as mine." response.
    BTW, the reason meL supports the BasicStamp codes is that Xout (and Xin) were original BasicStamp procedures. The non-Pro PB syntax is based on PBasic.
  1. How to drive the Vinculum VDIP1 in UART mode
    By BrianT in forum Code Examples
    Last Post: - 23rd May 2013, 13:34
  2. Loop with two motor and 2 sensors
  3. USB-FTDI[UM232R] with PIC16f877a
    By bjox in forum USB
    Last Post: - 23rd February 2008, 23:40
  4. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 13:22
  5. One wire serial comms on +5V line
    By MegaADY in forum mel PIC BASIC Pro
    Last Post: - 21st May 2005, 13:49
