Which chip do i use?
Results 1 to 40 of 78
    Jun 2007
    Mansfield, UK
    Whats ISR mean?
    I have an idea of how i can write this code in a few simple lines but i dont know how to use interrupts at all. I assume i have 2 interrupts. If one of them goes low then that is the zero-crossing and the code will goto the PWM area. If the second interrupt pin (serial) changes then do i run serin toget the data or wouldnt that work?
    2 main things i need to know at the moment.
    Which chip do i need?
    How do i detect interrupts?
    BTW. Im buying all my parts from http://www.rapidonline.com so it would be nice if i could get the chip from there. I dont think that last one i found is available from them.
    Edit: Do the PIC codes mean anything? Like 16F = 20 pin, 18F = 40 pin etc. Or do they just increment with each new chip?
    ISR: Interrupt Service Routine : It's the code area used when an interrupt happen.
    Begin with ON INTERRUPT and/or Darrel's Instant interrupts.
    Jun 2007
    Mansfield, UK
    Ive just googled it and based on this satement "Once you try this, you may never use ON INTERRUPT again." I think i should just use Darrel's Instant Interrupts. Ill have a read and see what i can come up with. Thanx
  1. Trouble with PIC16F88 (chip hangs up)
    By nobner in forum mel PIC BASIC Pro
    Last Post: - 20th January 2009, 10:23
  2. Camera with PIC chip
    Last Post: - 1st July 2008, 15:28
  3. More info on L4620 liquid sensor chip
    By Nicmus in forum Documentation
    Last Post: - 2nd June 2008, 00:03
  4. TV Display Chip
    By zadok in forum mel PIC BASIC Pro
    Last Post: - 17th April 2008, 23:17
  5. chip selection aid
    By PICMAN in forum General
    Last Post: - 21st February 2005, 19:33
