Stepper Motor Program
Results 1 to 4 of 4
    Oct 2007
    Default Stepper Motor Program
    I have got a stepper motor working nicely on a basic stamp with the following code. But am unsure of what changes should I make for the same code to work on a PIC. I understand most of what is going on but am a bit unsure about what the Phase is about and the OUTB
    Phase VAR OUTB ' phase control outputs
    idx VAR Byte ' loop counter
    stpIdx VAR Nib ' step pointer
    stpDelay VAR Byte ' delay for speed control
    Steps DATA %0011, %0110, %1100, %1001
    Setup:
    DIRB = %1111 ' make P4..P7 outputs
    stpDelay = 5 ' set step delay
    FOR idx = 1 TO 200 ' one revolution
    GOSUB Step_Fwd ' rotate clockwise
    NEXT
    PAUSE 500 ' wait 1/2 second
    GOSUB Step_Rev ' rotate counter-clockwise
    NEXT
    GOTO Main
    ' -----[ Subroutines ]-----------------------------------------------------
    Step_Fwd:
    stpIdx = stpIdx + 1 // 4 ' point to next step
    GOTO Do_Step
    Step_Rev:
    stpIdx = stpIdx + 3 // 4 ' point to previous step
    GOTO Do_Step
    Do_Step:
    READ (Steps + stpIdx), Phase ' output new phase data
    PAUSE stpDelay ' pause between steps
    Hi kiwipiper,
    No Dirs in PBP so DIR = 1111 becomes TRISB = %0000 ' make lower B ports outputs
    change NIB to BYTE as no NIBs in PBP
    Phase VAR OUTB ' phase control outputs - not sure what to do here . . . what does this do in stamp lingo?
    stpDelay = 5 would be stpDelay CON 5
    It has been awhile since I stamped, but this should get you going with PIC BASIC.
    http://www.picbasic.co.uk/forum/show...hlight=stepper
    Oct 2007
    Default Solved
    Thanks for that, got it working not as elegantly as the first program but it does the job.
    Here is the code, any suggestions on making it a bit more elegant wouild be appreciated.
    TRISB = %00000000
    speed var word
    i var byte
    speed = 10
    FOR i = 1 TO 50 ' one revolution
    NEXT i
    NEXT i
    GOTO Main
    Step_Fwd:
    portb = %1001
    pause speed
    portb = %1100
    pause speed
    portb = %0110
    pause speed
    portb = %0011
    pause speed
    Step_Rev:
    portb = %0011
    pause speed
    portb = %0110
    pause speed
    portb = %1100
    pause speed
    portb = %1001
    pause speed
  1. 18f4431; driving a stepper IN HARDWARE mode
    By DDDvvv in forum mel PIC BASIC Pro
    Last Post: - 21st January 2010, 16:49
  2. Replies: 11
    Last Post: - 6th November 2008, 10:27
  3. Controlling stepper motor with PIC
    Last Post: - 1st July 2008, 10:21
  4. Driving Stepper Motor with PBL3717
    By crhomberg in forum mel PIC BASIC Pro
    Last Post: - 8th November 2007, 20:59
  5. problem with stepper!!
    By ibra in forum mel PIC BASIC Pro
    Last Post: - 7th August 2007, 16:41
