adding with 7 segments
Results 1 to 5 of 5
    Default adding with 7 segments
    Hi guys,
    i'm experimenting with some 7 segment displays and my 16F84A.
    I can get fixed values to work ( like portb=$40 and b5=5 and lookup the value )
    But when i try to increment b5 and output the result i get strange readings...
    What is wrong ?
    Must i do this in a different way ?
    Here's the code:
    '7 segment display test
    'device 16F84
    '7 seg portb
    '1 button porta.0
    '1 button porta.1
    init:
    'a var portb.0
    'b var portb.1
    'c var portb.2
    'd var portb.3
    'e var portb.4
    'f var portb.5
    'g var portb.6
    'dp var portb.7
    b5 var word
    input porta
    TRISB = $80
    portb=$40
    pause 1500
    start:
    b5=5
    loop:
    if porta.1 =1 then
    b5=b5+1
    Lookup b5, [$40, $79, $24, $30, $19, $12, $02, $78, $00, $18], b5
    portb=$ff
    portb=b5
    pause 300
    if porta.0 =1 then
    b5=b5-1
    Lookup b5, [$40, $79, $24, $30, $19, $12, $02, $78, $00, $18], B5
    portb=$ff
    portb=b5
    pause 300
    if (porta.0=0) and (porta.1=0) then
    portb=$ff
    portb=b5
    pause 300
    goto loop
    i think i got it:
    had to change
    to
    Lookup b5, [$40, $79, $24, $30, $19, $12, $02, $78, $00, $18], B1
    I got things to work with one 7segment display.
    I tryed to follow the article here with 2 7segments:
    http://www.melabs.com/resources/articles/ledart.htm
    but i cant get it to work...
    Had to do some minor changes as some original lines were giving me errors...
    something is missing here
    here's the code:
    B1 var word
    W1 var word
    B0 var word
    B3 var word
    TRISB = $80
    loop: For B1 = 0 To 99 ' Count from 0 to 99
    B0 = B1 ' Pass the count to the conversion subroutine
    gosub display4
    Pause 1000 ' Display it for 1 second
    Next B1 ' Do next
    Goto loop ' Do it forever
    ' Convert binary number in B0 to segments for LED
    bin2seg: Lookup B0,[$40,$79,$24,$30,$19,$12,$02,$78,$00,$18],B3
    display4:
    B0 = W1 / 10 ' Find number of tens
    W1 = W1 // 10 ' Remove tens from W1
    Gosub bin2seg ' Convert number to segments
    Poke PortB, B3 ' Send segments to LED
    Poke PortA, $1D ' Turn on second digit
    Pause 1 ' Leave it on 1 ms
    Poke PortA, $1F ' Turn off digit to prevent ghosting
    B0 = W1 ' Get number of ones
    Poke PortA, $1E ' Turn on first digit
    have a look at this one
    http://melabs.com/resources/samples/pbp/7segment.pbp
    and change Display sub.
    For i = 0 To 3 ' Loop through 4 digits
    to
    For i = 0 To 1 ' Loop through 2 digits
    If you're using PBP, this will work, if you're using PBC... it might cause some headaches
    Thanks it works now
    one note:
    i have slowed down the count by adding a pause 500...
    mainloop:
    For Value = 0 To 99
    GoSub display ' Display the value
    pause 500 'slow count
    Next Value
    However i notice that one digit ( number ones ) stays most of the time off while the second digit ( number tens ) stays most of the time on.
    I've tryed to change the pause 1 to pause 50 but not better result.
    display:
    n = Value Dig i ' Get digit to display
    GoSub display1 ' Display the digit
    Pause 1 ' Leave it on 1 millisecond
    Next i ' Do next digit
    Is there a way to level this ?
  1. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 08:31
  2. LED Machine Tach For Tired Eyes
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 15:55
  3. 7 segments clock
    By the_apprentice in forum mel PIC BASIC Pro
    Last Post: - 27th April 2006, 19:45
  4. 7 segment digit problem (using Mister E's code)
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 9th September 2005, 21:25
  5. WRITE not working
    By servo260 in forum mel PIC BASIC Pro
    Last Post: - 29th December 2004, 03:02
