help with multiple outputs...
Results 1 to 2 of 2
    Nov 2007
    Default help with multiple outputs...
    I am new to programming with picBasic Pro. I have used the parallax version. Here is the trouble I am having....
    I want to sequence 2 outputs, triggered by a push button. In words, this is what i want to happen:
    if button is pressed
    turn on 1st output
    wait half a second
    turn on 2nd output (1st output must stay on)
    wait half a second
    turn 2nd output off
    wait 3 seconds
    turn 1st output off
    my coding goes like this:
    if portb.6 = 1 then
    goto activate
    high portc.0
    activate:
    high portc.0
    high portc.1
    low portc.1
    pause 3000
    low portc.0
    it works fine, except portc.0 shuts itself off when i call portc.1 high. I have tried a variety of simple programs, but can only get one output on at a time.
    What am I doing wrong? Basic Stamp editor holds the output high until it is instructed to move it low.
    Hi rickvan,
    Which PIC are you using? My guess is that it has a comparator or something else on the same pins that needs to be turned off.
    EDIT: Oh, I see, you've got help in another thread.
  1. Multiple PICS from Same Crystal?
    By WOZZY-2010 in forum General
    Last Post: - 6th February 2010, 16:18
  2. 30 PWM outputs on one chip?
    Last Post: - 25th September 2009, 17:32
  3. multiple outputs on....
    By rickvan in forum mel PIC BASIC Pro
    Last Post: - 25th November 2007, 17:55
  4. Problems controlling multiple pics
    By gandora in forum mel PIC BASIC Pro
    Last Post: - 29th May 2007, 09:59
  5. Multiple IR LEDs from 1 port using transistor
    By belpe123 in forum General
    Last Post: - 20th May 2005, 23:07
