Ports to In and Out at same time
Results 1 to 3 of 3
    Feb 2005
    Smile Ports to In and Out at same time
    I looked at the bitwise functions, and the examples given in
    http://www.picbasic.co.uk/forum/show...hlight=masking
    Say you want PortB.0 as Input and Rest as Outputs
    Assuming you set
    TRISB = &10000000 '
    then
    PortB = PortBnewdata & $FE ' Will this only change the values on bits 1 to 7
    ' and leave the value of the input on bit 0 the same
    ' ie as an input ?
    kind regards
    Peter
    Pete
    Quote Originally Posted by Peter1960 View Post
    Assuming you set
    TRISB = &10000000 ' . . . .
    Switch 'er around Peter
    TRISB = %00000001 sets PortB.0 as input
    This will leave all <7:1> as is BUT it will clear bit0
    Assuming PortBnedata=$FF - AND with $FE give... $FE
    If you want set set a bit, you'll need to use -OR-
    Portb = PortBnewdata | $1
    You can use windows calc in scientific mode if you want. From the link you have posted, looked at the one i've posted about boolean operations/theory.
