Windows No Disk Error
Results 1 to 5 of 5
    in case it doesn't work, which i doubt, use regedit to clean up everything should work.. be carefull
    MicroCodeStudio Plus
    HKEY_CURRENT_USER\Software\MecaniqueUK\MicroCodeSt udioPlus\Editor
    and delete LastFile key
    HKEY_CURRENT_USER\Software\MecaniqueUK\MicroCodeSt udioPlus\FileHistory
    delete all keys, but leave default one
    HKEY_CURRENT_USER\Software\MecaniqueUK\MicroCodeSt udioPlus\FileItems
    delete all key as well, but leave default one
    i don't have the regular version, but you should find something around the above.
    HTH
  1. Using input from Switch to control a loop
    Last Post: - 2nd February 2009, 06:02
  2. Loop with two motor and 2 sensors
  3. Optimizing DIV
    Last Post: - 22nd September 2008, 05:58
  4. pbp245 compliation error
    By Woodzy in forum mel PIC BASIC Pro
    Last Post: - 25th July 2006, 06:59
  5. 16F88 Compile error
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 01:22
