Windows No Disk Error
Results 1 to 5 of 5
    Nov 2007
    Default Windows No Disk Error
    I am getting this error when I click on File while using MicroCode.
    I loaded a file from my A:\ and now no matter what I do I get this ERROR.
    I have closed MCS, then ran MCS and then tried to open a file and I get this ERROR.
    The only time it works is when I have a disk in A:\. Even though I am not trying to access A:\.
    MCS has been working fine until I used a:\
    How do I get around this problem without leaving a disk in a:\?
    HELP
    Thanks, Lee
    Just a Guess....
    Check the Default Folder in the MCS options.
    Make sure it's not pointing to A:\
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=2150&stc=1&d=119593610 0">
    Second guess ...
    Un-check the Open last file(s) when application starts checkbox.
    Nov 2007
    Smile Windows No Disk Error
    Thanks for the help. I unchecked last file box. Still had to put a disk into a:\.
    I opened a file on C:\pbp and exited MCS. I removed the a:\ disk.
    I rechecked the last files box.
    I ran MCS again and tried to open a file and EVERTHING is working again.
    Thank, Everybody, Lee
    in case it doesn't work, which i doubt, use regedit to clean up everything should work.. be carefull
    MicroCodeStudio Plus
    HKEY_CURRENT_USER\Software\MecaniqueUK\MicroCodeSt udioPlus\Editor
    and delete LastFile key
    HKEY_CURRENT_USER\Software\MecaniqueUK\MicroCodeSt udioPlus\FileHistory
    delete all keys, but leave default one
    HKEY_CURRENT_USER\Software\MecaniqueUK\MicroCodeSt udioPlus\FileItems
    delete all key as well, but leave default one
    i don't have the regular version, but you should find something around the above.
    HTH
  1. Using input from Switch to control a loop
    Last Post: - 2nd February 2009, 06:02
  2. Loop with two motor and 2 sensors
  3. Optimizing DIV
    Last Post: - 22nd September 2008, 05:58
  4. pbp245 compliation error
    By Woodzy in forum mel PIC BASIC Pro
    Last Post: - 25th July 2006, 06:59
  5. 16F88 Compile error
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 01:22
