Pcf8563p Rtc Trouble
Results 1 to 8 of 8
    Jul 2007
    Default Pcf8563p Rtc Trouble
    I'm using the PCF8563P rtc, i can not get it to work
    ive never used the i2c protocol before, so maybe ive messed it up?
    ive looked through the posts already present on the forum concerning the subject
    and cannot figure it out.
    i would be grateful of any help
    just using the basic 16f84 mcu
    'rtc pins
    clk_pin var portb.5
    data_pin var portb.4
    'register address's
     reg_seconds        CON  $02
     reg_minutes        con  $03
     reg_hours          con  $04
     reg_days           con  $05
     reg_weekdays       con  $06
     reg_months_century con  $07
     reg_years          con  $08
     reg_minute_alarm   con  $09
     reg_hour_alarm     con  $0A
     reg_day_alarm      con  $0B
     reg_weekday_alarm  con  $0C
     rtc_write var byte
     rtc_read  var byte
     rtc_write=$a2
     rtc_read=$a3
     'time variables
     seconds var byte
     minutes var byte
     hours var byte
     days var byte
     years var byte
      'initial time variable values
      seconds=0
      minutes=0
      hours=18
      days=23
      years=7
      init:
     lcdout $fe,1
     lcdout "Real Time Clock"
    I2CWrite data_pin,clk_pin,rtc_write,reg_seconds,[seconds]
    pause 10
    I2CWrite data_pin,clk_pin,rtc_write,reg_minutes,[minutes]
    pause 10
    I2CWrite data_pin,clk_pin,rtc_write,reg_hours,[hours]
    pause 10
    I2CWrite data_pin,clk_pin,rtc_write,reg_days,[days]
    pause 10
    I2CWrite data_pin,clk_pin,rtc_write,reg_years,[years]
    pause 10
     I2CRead data_pin,clk_pin,rtc_read,reg_seconds,[seconds]
     pause 10
     I2CRead data_pin,clk_pin,rtc_read,reg_minutes,[minutes]
     pause 10
     I2CRead data_pin,clk_pin,rtc_read,reg_hours,[hours]
     pause 10
     I2CRead data_pin,clk_pin,rtc_read,reg_days,[days]
     pause 10
     I2CRead data_pin,clk_pin,rtc_read, reg_years,[years]
     pause 10
    lcdout $fe,1  ' clear lcd
    lcdout dec2 hours,":",dec2 minutes,":", dec2 seconds," "
    Jul 2007
    Bavaria
    Hello Dan,
    I had started a project using the PCF8563 a bout a year ago (not yet finished).
    Without deeper analysing your code, I noticed, that you are using different addresses for read and write.
    PBP handles this for you, read/write always to the address $A2.
    You could also shorten your code by using multiple reads/writes like
    I2CRead data_pin,clk_pin,rtc_read,reg_seconds,[seconds, minutes, hours...]
    Ingo
    Jul 2007
    Quote Originally Posted by inse View Post
    Hello Dan,
    Ingo
    hi
    did you get the pcf8563 to work then ?
    in the datasheet it had different addresses for writing and reading so i just used them both in my code to be safe, ive changed a few things now i get 08:08:08 displayed i don't no we re those values come from, because there not the ones i'm writing to the registers
    confuuuuusion!
    Jul 2007
    anyone have any idea's then
    one thing i forgot to do was add pull up resistors on the data and clock lines so i added 10k resistors to them and i get the values 16 for hours minutes and seconds, whether connected to the rtc or not.
    with the data line being bi directional i don't no what to do in means of setting it as an input or an ouput, or do i just not define it as either.
    Dan
    Bombay, India
    - Dan -
    I don't have exactly what you want, but I have worked on a PCF8583 from Philips. Perhaps they are similar. You figure it out. Use it as a guideline if you may. Part of init is to set the SDA and SCL lines as outputs via the TRIS command.
    ' I2C   RTC PCF8583  CODE  using I2C_read and I2C_write routines of compiler
    ' RTC registers are defined
    ' 0       -       Command / Status register
    '   .0  timer flag
    '   .1  alarm flag
    '   .2  alarm enable 1 -  enabled
    '   .3  mask flag
    '   .54  function 00 clock 32.768KHz/01 clock 50Hz/10 evt counter/11 test
    '   .6  hold last count flag
    '   .7  stop counting, reset divider
    ' 1       -       1/10 s | 1/100s
    ' 2       -       10s    | 1s       seconds
    ' 3       -       10m    | 1m       minutes
    ' 4       -       10h    | 1h       hours
    '   .3..0 unit hours BCD
    '   .54   10s hours 0..2 binary
    '   .6    1 PM
    '   .7    1 12 hour format
    ' 5       -       10d    | 1day     Day & Year
    '   .3..0 unit days BCD
    '   .54   ten days 0..3 binary
    '   .76   year 0..3 binary (read 0 if mask)
    ' 6       -       10mo   | 1month   month
    '   .3..0 unit months BCD
    '   .4    ten months
    '   .7..5 weekdays 0..6 binary (read 0 if masked)
    ' 0x10 to 0xff  RAM
    ' If RTC is not running, start it
    TimerOff:
        I2CWRITE SDA, SCL, $A2, ControlReg, [0]
    ' Read the time in BCD format
    RTC_GetTime:
        I2Cread SDA, SCL, $A2, SecondsReg+0, [Time[2],Time[1],Time[0]]
    ' Set time in BCD format
    RTC_SetTime:
        I2Cwrite  SDA, SCL, $A2, SecondsReg+0, [Time[2],Time[1],Time[0]]
        goto  TimerOff
    Jul 2007
    Bavaria
    Hi Dan,
    i hope you got ahead with your code in the meantime.
    My project is a clock (who could guess it?) with electromechanic seven segment displays.
    The clock is running (1/2 hour behind by now) but the code for setting the time is still missing - as well as the buttons to be used for it.
    You don't have to initialize the pins you use for I2C, it is done by the i2cread/i2cwrite commands.
    I don't see what is causing the communication problems in your code - so i propose you check your hardware wiring.
    Best wishes,
    Ingo
    Default Maybe this can help
    I have not used the Philips RTC but I am sure the basic device will be similar to the DS 1629 that I use.
    I notice you are writing to the chip in single bytes. You should be able to write an entire string and save on the eerom write delays.
    Here is a code snip.
    ConfigureClock:
    i2cwrite sda, scl, %10011110, $AC, [$A0]
    ' Write to Configuration Register $AC with value $A0.
    ' See page 10 of DS1629 data sheet. Disables all alarms.
    SetClock:
    ' Set up current time parameters - MUST be in BCD format
    ' note HEX is the same as BCD for this application
    ' Set for UTC which is AEST - 10 hours
    ' debug 13, 10, " Writing to clock", 13, 10
    RTCSec = $00 ' Seconds NOTE 00 enables, 80 halts oscillator
    read 49, RTCMin ' Minutes
    read 50, RTCHour ' Hours
    read 51, RTCDate ' Date
    read 52, rTCMonth ' Months
    read 53, RTCYear ' Year
    RTCWDay = $04 ' Weekday - arbitrary number 1-7 (not used)
    WriteClock: ' Write setup info.
    I2Cwrite SDA,SCl,%10011110,$C0,$00,[RTCSec,RTCMin,RTCHour,_
    RTCWDay,RTCDate,RTCMonth,RTCYear]
    ' set DS1629 into 'convert on demand' mode to save power
    ' write to $AC -
    ' No Alarm, active LOW, single conversion on command
    ' MSB = %00000101
    i2cwrite SDA, SCl, %10011110, $AC, [ %10100000]
    gosub lowestpower
    And another snip.
    ShowTime:
    'fetch current time
    I2CRead SDA,SCl,%10011110,$C0,$00,[RTCSec,RTCMin,RTCHour,RTCWDay,_
    'display current time
    debug $0D, $0A, "200", #rtcyear & $0F, "/", #rtcmonth >> 4 & $0F,_
    #rtcmonth & $0F , "/", #RTCDate>> 4 & $0F, #RTCDate& $0F, ", ",_
    #rtchour >> 4 & $0F, #rtchour & $0F, ":", #rtcmin >> 4 & $0F,_
    #rtcmin & $0F,":", #rtcsec >> 4 & $0F, #rtcsec & $0F
    HTH
    Brian
  1. Low battery signal from an RTC
    By ardhuru in forum mel PIC BASIC Pro
    Last Post: - 19th March 2008, 17:13
  2. PIC 16F877 I2C communications
    By sigmoideng in forum General
    Last Post: - 13th July 2007, 10:28
  3. Using RTC to generate long time delays
    By schlaray in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2007, 00:31
  4. Another RTC, DS1287
    Last Post: - 12th December 2006, 17:07
  5. X1226 RTC - Help
    By charudatt in forum mel PIC BASIC Pro
    Last Post: - 14th August 2006, 17:54
