Receiving POCSAG with PBP
Results 1 to 7 of 7
    Bob Smith's Avatar
    Bob Smith Guest
    Default Receiving POCSAG with PBP
    Has anyone written code to decode a POCSAG paging signal? I have a pager and would like to duplicate its call number into a PIC to control things (switch lights on and off etc.).
    Any pointers and tips to save me loosing the last of my hair!
    Bob Smith
    L_Gaminde's Avatar
    L_Gaminde Guest
    I have done this using a PC and a scanner, using a small adapter board, I would think it could be done, I have thought about doing it also, but never took it any futher. You will need a radio that you can tap into, using the speaker input will not work.
    L_Gaminde's Avatar
    L_Gaminde Guest
    L_Gaminde's Avatar
    L_Gaminde Guest
    Here is the circuit for Pocsag when not using a soundcard and may work with Pic's
    http://www.qsl.net/g4hbt/pogsac.htm
    Bob Smith's Avatar
    Bob Smith Guest
    Many thanks for the info.
    I did write POCSAG encoder code in xbasic (shows how long ago that was!) for the PC. But with memory fading and age increasing I was checking to see if it had already been done.
    Will start on the code soon but it will take me some time to finish (part time hobby).
    Bob
    ghyaward's Avatar
    ghyaward Guest
    Default Have you had any luck with this project?
    Bob, did you ever get a decoder running? I'm about to start on the same project and did not want to re-invent the wheel.
    lahloumidi's Avatar
    lahloumidi Guest
    Thumbs up Pocsag Decoder Runing
    I Have Recently DoNE Some REseArch About This Project And Finaly I Find What I Need The Famous Pocsag Decoder Based On A 16c84 Pic R 16f
    And I Have Done The Project And It Work Very Good
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
  2. Extensions to PBP variables
    By John_Mac in forum mel PIC BASIC Pro
    Last Post: - 23rd October 2009, 06:21
    Last Post: - 2nd May 2006, 20:01
    Last Post: - 18th December 2005, 00:30
  5. USB Receiving a Word
    By sean-h in forum USB
    Last Post: - 9th October 2005, 17:56
