Hi Melanie!
Is the sample.bas that you posted about how to read and write the EEPROM applicable for 16F877A?
If not, what certain modifications should be done?
Please help...
ria
Hi Melanie!
Please help...
ria
Adam - *blush* personally Signed framed Masterpieces are available in exchange for internationally negotiable crinkly drinking vouchers...
Ria - Yes it is, with a few changes...
1. Change ALL the PIC defines to 877A instead 876A...
eg
@ DEVICE pic16F876A, XT_OSC
becomes
@ DEVICE pic16F877A, XT_OSC
2. Add additional TRIS statements to account for Ports D and E.
eg
TRISE=%11111111
Remembering that parts of PortE will still have Analog on them...
3. Compile with the command line
PBPW -p16f877A sample -v
I see..
Thank you so much Melanie..
I really learn a lot from this forum.
Cheers!
ria
By the way Melanie..why we need to use PBPW instead of PBP in compiling?
What's the difference between them?
Hi Melanie,
I got your code running, initially I placed '9999' at memory location 0. I'm trying
to read it from the internal memory, So I try this code below. But when I press the button I got '655535'
instead the initial value '9999'.
TRISB=%00010000 ' All PortB is Output - except
' B.3 = Button
TRISC=%00000000 ' All PortC is Output
CMCON=%00000111 ' Disable Comparators
CVRCON=%00000000 ' Disable Reference Module
OPTION_REG.7=0 ' Enable Weak Pull-Up's
Pause 2000
ButtonPRESS var PortB.4 ' Push Button
WORDVariable var WORD
PromptLoop:
Serout PortC.1,6, [$FE,1,"Press Button..."]
While ButtonPRESS=1:Wend ' Wait here until Button Pressed
READ 0,WORDVariable.HighByte ' Reconstruct Word variable from EEPROM
READ 1,WORDVariable.LowByte
Serout PortC.1,6, [$FE,1,"Reading=",#WORDVariable] ' Display Result
While ButtonPress=0:Wend ' Wait here as long as finger is on Button
Goto PromptLoop
Thanks for the time, appreciate it very much,
joe
Make sure your PIC programmer program the EEPROM location, unless.. you may read an empty EEPROM $FFFF
Now depending of how you wrote your DATA line, this may work.. or not.
should work.Code:data @0, WORD 9999
Your PICProgrammer software should allow to see the EEPROM section, just compile your code, import the .HEX and look if your data is saved in the EEPROM.
Thanks all, I got it to work. But I've noticed that every time I compile it the data '9999' in Address 0 restarts to 655535. How can I prevent it from overwriting. So that every time I check Address 0 the same data will show.
Thanks all,
joe
