Write and Read from internal Memory
Results 1 to 11 of 11
    Default Write and Read from internal Memory
    Greetings PICperts!
    Can anyone share a code that will write to the internal memory of PIC16F876A the value "1234"
    and display the value when I press a button. I have download an example but I don't really understand how it works.. A simple code will be great to help me get started.
    joe
    Compiled OK with line...
    pbpw -p16f876a sample -v
    Lots of embedded comments to tell you what's happening...
    Enjoy
    	'	Sample.BAS
    	'	Target Processor PIC16F876A-04
    	'	Write value '1234' to internal EEPROM
    	'	When Button Pressed Read EEPROM value and Display on LCD
    	'	CPU Hardware Layout
    	'	PortA.0 - Unused - Set to INPUT
    	'	PortA.1 - Unused - Set to INPUT
    	'	PortA.2 - Unused - Set to INPUT
    	'	PortA.3 - Unused - Set to INPUT
    	'	PortA.4 - Unused - Set to INPUT
    	'	PortA.5 - Unused - Set to INPUT
    	'	PortB.0	- Button - Connect between this PIC Pin and Vss (0v)
    	'		- uses internal PICs pull-up's
    	'	PortB.1 - Unused - Set to OUTPUT
    	'	PortB.2 - LCD - RS
    	'	PortB.3 - LCD - E
    	'	PortB.4 - LCD - DB4
    	'	PortB.5 - LCD - DB5
    	'	PortB.6 - LCD - DB6
    	'	PortB.7 - LCD - DB7
    	'	PortC.0	- Unused - Set to OUTPUT
    	'	PortC.1 - Unused - Set to OUTPUT
    	'	PortC.2 - Unused - Set to OUTPUT
    	'	PortC.3 - Unused - Set to OUTPUT
    	'	PortC.4 - Unused - Set to OUTPUT
    	'	PortC.5 - Unused - Set to OUTPUT
    	'	PortC.6 - Unused - Set to OUTPUT
    	'	PortC.7 - Unused - Set to OUTPUT
    	'	PIC Defines
    	@ DEVICE pic16F876A, XT_OSC		' System Clock Options
    	@ DEVICE pic16F876A, WDT_ON		' Watchdog Timer
    	@ DEVICE pic16F876A, PWRT_ON		' Power-On Timer
    	@ DEVICE pic16F876A, BOD_ON		' Brown-Out Detect
    	@ DEVICE pic16F876A, LVP_OFF		' Low-Voltage Programming
    	@ DEVICE pic16F876A, CPD_OFF		' Data Memory Code Protect
    	@ DEVICE pic16F876A, PROTECT_OFF	' Program Code Protection
    	@ DEVICE pic16F876A, WRT_OFF		' Flash Memory Word Enable
    	'	Hardware Defines
    		' 	LCD Display
    	Define LCD_DREG PORTB			' Port for LCD Data
    	Define LCD_DBIT 4			' Use upper 4 bits of Port
    	Define LCD_RSREG PORTB			' Port for RegisterSelect (RS) bit
    	Define LCD_RSBIT 2			' Port Pin for RS bit
    	Define LCD_EREG PORTB			' Port for Enable (E) bit
    	Define LCD_EBIT 3			' Port Pin for E bit
    	Define LCB_BITS 4			' Using 4-bit bus
    	Define LCD_LINES 2			' Using 2 line Display
    	Define LCD_COMMANDUS 2000		' Command Delay (uS)
    	Define LCD_DATAUS 50			' Data Delay (uS)
    		'	Button Inputs
    	ButtonPRESS var PortB.0			' Push Button
    	'	EEPROM
    	MemoryA		DATA @0,0		' The TWO memory locations for saving WORD variable
    	MemoryB		DATA 0			' Both Preset to Zero
    	'	RAM Assignments & Variables
    	WORDVariable var WORD			' Just a WORD variable we're going to use
    	'	Start Program
    	'	Set-up Hardware
    	TRISA=%00111111				' All available PortA is Input
    						' Remember it's still in ANALOG Mode
    	TRISB=%00000001				' All PortB is Output - except
    							' B.0 = Button
    	TRISC=%00000000				' All PortC is Output
    	CMCON=%00000111				' Disable Comparators
    	CVRCON=%00000000			' Disable Reference Module
    	OPTION_REG.7=0				' Enable Weak Pull-Up's
    	Pause 2000				' Wait for LCD to settle
    	'	Save Value into EEPROM
    	WORDVariable=1234
    	LCDOut $FE,1,"Writing=",#WordVariable	' Tell user what we're doing...
    	WRITE MemoryA,WORDVariable.HighByte	' Save one Byte from Word to EEPROM Location 0
    	WRITE MemoryB,WORDVariable.LowByte	' Save other Byte from Word to EEPROM Location 1
    	Pause 2000				' Just a pause so you can read what's on the LCD
    	'	Prompt for Button Press
    PromptLoop:
    	LCDOut $FE,1,"Press Button..."
    	While ButtonPRESS=1:Wend		' Wait here until Button Pressed
    	READ MemoryA,WORDVariable.HighByte	' Reconstruct Word variable from EEPROM
    	READ MemoryB,WORDVariable.LowByte
    	LCDOut $FE,1,"Reading=",#WORDVariable	' Display Result
    	While ButtonPress=0:Wend		' Wait here as long as finger is on Button
    	Goto PromptLoop
    Melanie,
    Thanks for your fast reply, I will work this out and let you know the outcome later.
    regards,
    joe
    Apr 2006
    New Hampshire USA
    Smile Thanks
    Thank you for the great sample, Melanie.
    The comments make it a real tutorial on reading and writing to EEPROM. The logic and flow are a glimpse into the world of how professionals write code. Very impressive.
    I will be studying this masterpiece for some time to come.
    -Adam-
    Nov 2007
    Cebu, Philippines
    Default using 16F877A
    Hi Melanie!
    Is the sample.bas that you posted about how to read and write the EEPROM applicable for 16F877A?
    If not, what certain modifications should be done?
    Please help...
    ria
    Adam - *blush* personally Signed framed Masterpieces are available in exchange for internationally negotiable crinkly drinking vouchers...
    Ria - Yes it is, with a few changes...
    1. Change ALL the PIC defines to 877A instead 876A...
    eg
    becomes
    @ DEVICE pic16F877A, XT_OSC
    2. Add additional TRIS statements to account for Ports D and E.
    eg
    TRISE=%11111111
    Remembering that parts of PortE will still have Analog on them...
    3. Compile with the command line
    PBPW -p16f877A sample -v
    Nov 2007
    Cebu, Philippines
    Default thank you
    I see..
    Thank you so much Melanie..
    I really learn a lot from this forum.
    Cheers!
    ria
    Nov 2007
    Cebu, Philippines
    Default PBP vs PBPW
    By the way Melanie..why we need to use PBPW instead of PBP in compiling?
    What's the difference between them?
    Hi Melanie,
    I got your code running, initially I placed '9999' at memory location 0. I'm trying
    to read it from the internal memory, So I try this code below. But when I press the button I got '655535'
    instead the initial value '9999'.
    TRISB=%00010000 ' All PortB is Output - except
    ' B.3 = Button
    Pause 2000
    ButtonPRESS var PortB.4 ' Push Button
    PromptLoop:
    Serout PortC.1,6, [$FE,1,"Press Button..."]
    READ 0,WORDVariable.HighByte ' Reconstruct Word variable from EEPROM
    READ 1,WORDVariable.LowByte
    Serout PortC.1,6, [$FE,1,"Reading=",#WORDVariable] ' Display Result
    Goto PromptLoop
    Thanks for the time, appreciate it very much,
    joe
    Make sure your PIC programmer program the EEPROM location, unless.. you may read an empty EEPROM $FFFF
    Now depending of how you wrote your DATA line, this may work.. or not.
    data  @0, WORD 9999
    should work.
    Your PICProgrammer software should allow to see the EEPROM section, just compile your code, import the .HEX and look if your data is saved in the EEPROM.
    Question Data in Address 0 keeps overwriting...
    Thanks all, I got it to work. But I've noticed that every time I compile it the data '9999' in Address 0 restarts to 655535. How can I prevent it from overwriting. So that every time I check Address 0 the same data will show.
    Thanks all,
    joe
  1. write -read problem?
    By turkuaz in forum mel PIC BASIC Pro
    Last Post: - 30th August 2009, 14:06
  2. Write Onewire data toa I2C memory / read ASCI
    By Eugeniu in forum mel PIC BASIC Pro
    Last Post: - 16th November 2008, 20:19
  3. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 15:19
  4. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 01:22
  5. Read / Write , To / From Internal EEPROM
    By charudatt in forum mel PIC BASIC Pro
    Last Post: - 31st October 2003, 03:23
