USB Programmer on e-bay
Results 1 to 9 of 9
    Can you post your code?
    Did you have a look at the following thread?
    At least from post 1 to 5
    EDIT: oh, make sure you have the latest MPLAB and PICKIT 2 software version
    MPLAB 8.00
    Pickit 2 : V2.40
    You may need to update your PICKIT 2 firmware
    try this one
        @ __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BOD_ON
             ' Internal Oscillator
             ' Enable watch dog timer
             ' Enable power up timer
             ' Disable MCLR pin
             ' Enable brown out detect
        TRISIO=%11001011 ' MCLR/PGD/PGC pin as input
        GPIO=0
        ANSEL = 0
        CMCON0= 7
    Start:
        gpio=255
        gpio=0
        goto start
    While programming, none of the MCLR/PGD/PGC pins should be loaded.
    Nov 2007
    Thanks for the reply. This is exactly what I needed. Actually, shortly after my last post, I found a link, http://www.melabs.com/support/config_defaults.htm that sorted it all out for me. Why this info isn't in the PBP manual baffles me!
    My code is now running, but it seems the logic on the inputs is inverted. Another magic register to tell it a high logic level = 1?
    Nov 2007
    OK. ANSEL register is the trick. I needed digital inputs, and it was configured for analog! I found the info in the data sheet. Thanks again Mister e!
  1. Usb Programmer ?
    By iugmoh in forum USB
    Last Post: - 20th April 2008, 19:10
  2. USB programmer problem 18LF4620
    Last Post: - 8th November 2007, 03:03
  3. problems with USB programmer
    By malc-c in forum General
    Last Post: - 10th May 2007, 21:14
  4. USB programmer problems
    By uiucee2003 in forum USB
    Last Post: - 16th August 2006, 00:47
  5. Melabs USB Programmer
    By tmurph in forum General
    Last Post: - 25th December 2005, 04:25
