Hi!
What you need is a solid state relay with a 5V digital input and an AC switched output. You have to get one capable of switching an inductive load and you would be wise to purchase a relay that is considerably over rated. Most solid state relays will switch on with an input voltage of 3 volts. Also, it is best to get one that has an output that switches at zero crossing to minimize transients. I hope this helps.
