Single PIC As Both, Wireless Transmitter and Receiver
Results 1 to 4 of 4
    Oct 2007
    Default Single PIC As Both, Wireless Transmitter and Receiver
    Just curious if anyone has used a TWS-434 RF module and a RWS-434 RF module on single PIC? In other words, I'd like 1 PIC to be both, a transmitter and a receiver.
    Or possibly, are there any transmitter/receiver modules out there that are in a single package?
    Currently, I have a 16F877 setup as a transmiter with a TWS-434 sending data to a 12F675 setup as a receiver with a RWS-434. Everything is working perfectly now, but I'd like to have the 12F675 respond, or send data back to the 16F877 when asked.
    The 16F877 is hooked up to a PC and receives commands from a Visual Basic program. The 16F877 then sends appropriate commands to the 12F675.
    The 16F877 is essentially the master, so the 12F675 would only transmit if it was asked.
    Just wondering if there are any precautions or problems that I may encounter before I go about trying to setup.
    Any help or thoughts would be greatly appreciated... Thanks.
    Dec 2005
    You will probably need to remove power from the receiver while transmitting. These superregenerative receivers put out a lot of noise which can affect nearby transmitters. I've used them as translator/repeaters, receiving on one frequency and sending on another, allowing control of things like ceiling fans from an RF capable Pronto but, unless the transmitter and receiver were separated by several feet (or the receiver powered down), it would not work. I was using just a transmitter and receiver with no PIC so did not have the option of powering down the receiver.
    Oct 2007
    Thanks Dave.
    Good point. I was worried about interference between the receiver and transmitter being so close. I'll give it try.... Thanks.
    Bombay, India
    Yes I have done that. However, I have used separate frequencies for the transmitter and receiver. Transmitter is at 434MHz and receiver is 413Mhz(not sure) on one PIC and reversed on the other PIC.
  1. 433 Mhz Data Receiver
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 29th November 2010, 02:26
  2. transmitter receiver help
    By Deorge M in forum mel PIC BASIC Pro
    Last Post: - 11th June 2009, 07:17
  3. Simple Wireless Communication
    By jhorsburgh in forum General
    Last Post: - 27th March 2008, 11:02
  4. Wireless Transmitter
    By Mostafa in forum mel PIC BASIC Pro
    Last Post: - 18th July 2007, 10:49
  5. Serout problem
    Last Post: - 25th February 2007, 13:33
