Chip speed
Results 1 to 6 of 6
Thread: Chip speed
    Jun 2007
    Mansfield, UK
    Default Chip speed
    Hi. Is it possible to find out how long it takes to run a certain block of code?
    Yes indeed!
    at least 3 method
    1. use MPLAB sim or else simulator
    2. toggle a led and measure it with a scope
    3. use a PIC timer and show it on LCD or via SerialComm
    i like the Timer option as it measure the real stuff in a real environment. Have a look at the followings
    instruction execution time
    http://www.picbasic.co.uk/forum/showthread.php?t=365
    Now a collection of pretty nice and usefull tools...
    Example how to mix them all together...
    The Best Solution post #9
    http://www.picbasic.co.uk/forum/show...33&postcount=9
    The Best Solution --- The whole thread
    http://www.picbasic.co.uk/forum/show...ht=stuff+handy
    Once again... Thanks Darrel!
    You have a couple of options:
    ** Run it and time it in the simulator in MPLAB.
    ** Set a pin high when you enter the code section and low when you exit it. Look at the output with an oscilloscope.
    ** Use one of the PIC's timers to measure the execution time. Start it when you enter the section of code and stop it when you exit it. Someone (Darrel perhaps??) posted some code that was perfect for that but I can't seems to find it right now. I'll take another look.
    /Henrik Olsson.
    EDIT: OK Steve beat me to it. With nicer layout AND links to the code I was thinking about, and then some....
    even much funny, you said it in same order as me
    Oh stop,
    You're making me blush.
    EDIT: What am I saying ??
    &nbsp; &nbsp; Bring it on.<br>
    Jun 2007
    Mansfield, UK
    Wow. Thats a lot of stuff to be looking at. An oscilloscope is deffo out because i dont have one and i think they are expensive. Ive never used the simulator before but im guessing it runs on the PC and could be affected by other programs that are running. I will try out the timer method because it seems best. Ive just gotta have a good read through those links to find out how to use one.
    Thanx for the optimization bits too. I like things to be as optimized as possible.
  1. USB Speed
    By Rony in forum USB
    Last Post: - 24th August 2008, 20:43
  2. USB Speed
    By Rony in forum General
    Last Post: - 21st August 2008, 22:15
  3. Closed loop speed controller
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 26th January 2008, 14:15
  4. NEWB Help HPWM coding
    By Seafurymike in forum mel PIC BASIC Pro
    Last Post: - 1st January 2008, 21:52
  5. Replies: 14
    Last Post: - 26th September 2007, 05:41
