How to get PIC out of Sleep mode and turn-on LCD, vice versa ?
Results 1 to 4 of 4
    Nov 2007
    Default How to get PIC out of Sleep mode and turn-on LCD, vice versa ?
    I have PIC18F4525 connected to a LCD (16X2).
    1. I want to set the PIC into SLEEP mode.
    2. I want the LCD screen to turn-on when a push-button, connected to the PIC, is pressed. This means that the PIC should be switched out of SLEEP mode.
    3. The LCD screen should remain ON for the next 5 mins, displaying the desired result.
    4. The LCD should then turn-off after 5 mins, i.e. the PIC should go back into the SLEEP mode.
    I would really appreciate if you guys can give me suggestions on how to write a code for this.
    Thanks !
    Bombay, India
    Use the following lines of code
    @ sleep
    @ nop
    @ nop
    This will give indefinite sleep time
    Configure your PIC to generate an 'interrupt on port change'. You need not enable the interrupt. When the port change occurs, the PIC will execute the statements after sleep.
    Use some kind of timing code to achieve this; either using for loops or timer.
    Go back to number 1
    Nov 2007
    Thanks Jerson !!!
    I have come up with some kinda code which you can see in my new post titled - "Need help with SLEEP mode ".
    Please correct me on it. I would really appreciate everyone's suggestions and help.
    Thanks.
    Wink
    Hi, Aggie
    Some "bond" to your project ( LOL ):
    Here I use a 18F452
    LCD is powered Through a P-Mosfet ( Driven by PortB.4 ... LOW for ON )
    The "wakeup" interrupt is generated by a Low to High transition on Port B.1 ...
    see "sommeil" and "Wakeup" labels for what you look for ...
  1. High Power Consumption in Sleep Mode
    Last Post: - 18th September 2014, 14:29
  2. turn-off lcd and turn-on again
    By mehmetOzdemir in forum mel PIC BASIC Pro
    Last Post: - 5th September 2009, 13:57
  3. 16f688 LCD what have I done wrong
    Last Post: - 8th August 2009, 20:54
  4. Need help with SLEEP mode
    By aggie007 in forum mel PIC BASIC Pro
    Last Post: - 28th November 2007, 10:56
  5. Wierd sleep issue
    By orca in forum mel PIC BASIC Pro
    Last Post: - 14th March 2006, 23:06
