PIC 16F84A and 7segment LED dispay
Results 1 to 6 of 6
    Nov 2007
    Default PIC 16F84A and 7segment LED dispay
    hello,
    I have one small problem with routine for PIC 16F84A. Program must drive 7 segment LED display with comm. cathode. On output B port are PNP transistors via 4k7 for each segment.
    problem is following:
    RS232 values are ok and display lighted only 0. What is wrong here?
    porta.3 is serial input and value for B5 are 0-10. Var from LOOKUP are value for LED segment
    here is rotine:
    DEFINE OSC 16
    INCLUDE "MODEDEFS.BAS"
    dp var portb.0
    c var portb.1
    d var portb.2
    e var portb.3
    g var portb.4
    f var portb.5
    a var portb.6
    b var portb.7
    SDA VAR PORTA.3 'pin2
    b0 var byte
    b1 var byte
    b2 var byte
    b3 var byte
    b4 var byte
    b5 var byte
    trisa=%11111111
    trisb = %00000000
    clear
    START:
    serin sda,0,b2,b3,b4,b5
    lookup2 B5,[238,130,220,214,178,118,126,194,254,246,108],B1
    PORTB=B1
    GOTO START
    Similar routine i have write for a LCD display. Instead LOOKUP command is LCDOUT $fe,$80, #b5 and working ok.
    Sam
    it's more a matter of how the data is sent. You may try to change b5 to #b5 in SERIN line.
    doesn't work? comment out the SERIN line and use b5=3, it should display 3 on your 7 segment... right?
    Nov 2007
    hi Steve,
    I was trying with #b5 and display light allways 8 (all pins are low). The simple loop program, working ok and count normaly from 0 to 9
    here is a this sample1 (B5 count on LED display 0-9)
    start: for B5=0 to 9
    portb=b1
    next B5
    goto start
    sample 2 Instead lookup2 command have lcdout command. (working ok. B5 count 0 to 9 on LCD)
    start: serin SDA,0,b2,b3,b4,b5
    lcdout $fe,1,$80,#b5
    goto start
    sample 3. this sample show allways 0 on display. (B5 read lookup2 command and show 0 allways)
    dp var portb.0
    c var portb.1
    d var portb.2
    e var portb.3
    g var portb.4
    f var portb.5
    a var portb.6
    b var portb.7
    b0 var byte
    b1 var byte
    b2 var byte
    b3 var byte
    b4 var byte
    b5 var byte
    trisb = %00000000
    portb=b1
    goto start
    i was changed LOOKUP2 with LOOKUP and LED showing 8
    I have not anymore ideas
    regards
    Sam
    Nov 2007
    hi again,
    How read ASCII value from lookup command?
    regards,
    Sam
    How do you send the number to be displayed? By Hyperterminal for example and pressing the key '0'?
    i'll repeat what i told in previous post...
    start: serin SDA,0,b2,b3,b4,#b5
    portb=b1
    goto start
