Looking for a DAC
Results 1 to 5 of 5
    Omaha, Nebraska USA
    Default Looking for a DAC
    I'm looking for suggestions on a DAC.
    Requirements (for the moment) are 5 volt single-ended supply, 8-bit parallel, and DIP package.
    Anyone have any old (or new) favorites they'd care to recommend?
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    Mar 2006
    China
    Default How about...
    A R2R network and a generic op-amp would do the trick or the HPWM+filter plus an extra op-amp if you need more current is also one way. Then you only need one pin from the PIC.
    I haven't found a need for an external DAC since these 2 ways have been enough this far.
    /me
    For the recommended methods by Jumper, care should be givet to the selection of op-amps, since the requirement is 5V power supply.
    If you can tolerate serial communication, then ADC0831 is a nice part.
    Otherwise, ZN426 could also be used on 5V rail.
    The new D/A from Microchip looks interesting (MCP4725).
    Sorry, it's not the parallel device you're looking for.
    12-bit, op-amp Buffered output, I2C, with EEPROM, SOT23-6.
    http://www.microchip.com/stellent/id...cName=en532229
    http://news.thomasnet.com/fullstory/536152
    So new I'm not sure if you can even get them yet.
    Omaha, Nebraska USA
    Well, except for the 5V requirement, this looks like it might do the job:
    http://focus.ti.com/lit/ds/symlink/tlc7226.pdf
    Since I need two DACs, this may solve the problem in one package. And I do have an unregulated 16.5 VDC available.
    Russ
  1. Ti Dac 7553
    By GeoJoe in forum mel PIC BASIC Pro
    Last Post: - 28th August 2008, 20:29
  2. PIC18F4525 to DAC (PCF8591P) I2CWrite too fast?
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 4th April 2008, 08:16
  3. i2c with a dac
    By fabritio in forum mel PIC BASIC Pro
    Last Post: - 29th March 2006, 17:13
  4. Bluetooth wireless with PIC / HSERIN / DAC
    By rpatel in forum mel PIC BASIC Pro
    Last Post: - 20th December 2004, 22:13
  5. 10 bit pwm as dac
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 30th June 2004, 15:12
