Help with DS18B20 program
Results 1 to 39 of 39
    Oct 2007
    Vancouver, BC, Canada
    the thing is you have not mention how fast you are running your PIC. I found that problem when I ran my pic18f4550 with 20HMz, all I read back from the ds18b20 are zero/not connected. If I lower the chip to 4HMz then I can read the temperature.
    I don't know how to confirm this, the OWOUT and the OWIN command might be too fast for the ds18b20 to catch up with faster pic chip ?
    Check http://www.findchips.com This shows 6 distributors that stock the 18B20.
    Where are you located? I'll send you a used one (at least we know it's working)
    if you spring for the postage.
    But, before I wrote it off as bad, I would check with what KVLV just said. You might
    try using a different I/O-pin, different oscillator speed, etc.
    Try a timing test with say an LED on a port pin. Toggle it on & off. Does it toggle at the
    speed you expect? If not, it could be a timing issue, and that would definitely be a problem
    with 1-wire comms.
    LCDOUT can sometimes work just fine. Even if you have the wrong oscillator speed declared.
    So I would run a series of tests before I wrote the sensor off as bad. Just in case.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 09:54
  2. Replies: 1
    Last Post: - 23rd May 2009, 09:22
  3. Compile and Program help using PICKit2
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 10th March 2009, 14:51
  5. PIC16F684 Program question
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 28th December 2006, 14:30
