We had a problem similar to this but with the DS1620. The sensors actually measure the temperature of the circuit board, in your case the breadboard. How close is the voltage regulator to the sensor? Can you move the sensor to the opposite end of the board or remotely mount it? This will give you the most accurate temperature measurement since the thermal pathway is the pins on the part itself and not the plastic piece.
