Pic16f88
Results 1 to 6 of 6
Thread: Pic16f88
    Nov 2007
    Default Pic16f88
    Dear experts,
    I am new to this programing. I have a small project which i would like to get help with. Its a small car which should turn ON the lights and turn OFF with two buttons.
    Please help me.
    Hi and welcome.
    try the following
            '       Pic Configuration
            IFNDEF PM_USED
                list w=-207
                ;    Program Configuration Register 1
                cfg1 = _INTRC_IO & _WDT_OFF & _PWRTE_ON & _MCLR_OFF & _BODEN_ON & _LVP_OFF & _CCP1_RB0
                cfg2 = _CP_OFF  & _CPD_OFF & _WRT_PROTECT_OFF & _DEBUG_OFF
                __CONFIG    _CONFIG1, cfg1 & cfg2
                ;    Program Configuration Register 2
                __CONFIG    _CONFIG2, _IESO_OFF & _FCMEN_OFF
                list w=+207
                    device  INTRC_OSC_NOCLKOUT, WDT_OFF, PWRT_ON, MCLR_OFF, BOD_ON, LVP_OFF, CCPMX_OFF
                    device  PROTECT_OFF, CPD_OFF, WRT_OFF, DEBUG_OFF
                    device2 FCMEN_OFF, IESO_OFF
            OSCCON = %01100000 ' set to 4 MHz clock
            '       Hardware configuration
            TRISB=0     ' Set all PORTB pins to output
            TRISA=255   ' Set all PORTA pins to output
            ANSEL = 0   ' disable adc converters
            CMCON=7     ' disable analog comparator
            '       Hardware assignment
                    '       Push buttons
                    '       Push buttons are connected between PIC i/o and gnd
                    '       don't forget to add a pull-up resistor on the i/o too
            ONButton    VAR PORTA.0
            OFFButton   VAR PORTA.1
                    '       Light
                    '       LED connect between I/O and gnd... with a resistor in serie
            LIGHT       VAR PORTB.0
            '       Hardware initialisation
            WHILE OSCCON.2=0 : WEND     ' wait 'till internal OSC is stable
            PORTB=0                     ' clear all PORTB i/o
    START:
            if ONButton = 0 then
                light = 1   ' turn the LED on
            if offbutton = 0 then
                light = 0   ' turn the led off
            GOTO START
    Nov 2007
    thanks a lot, question! the above configs. can be done in the software as well right so i dont need to do those in the coding??
    yes you can do it in your programmer software as well... but you need to set them each time... and remind which one you need to set. Kinda annoying if months/years later you need to reprogram a PIC and you don't remind them.
    Once you load the .HEX file to program your PIC, your PIC Programmer software have to be smart enough to refresh the default one and to program them. Careful, some software need to be warned to do so.
    I ALWAYS set them in code, it's the right place to fit them.. not in a README.TXT or on a piece of paper sticked somewhere.
    But it's me
    EDIT: the above are way to much, but as i didn't know which assembler you're using (PM/MPASM) i've just put both and let the compiler choose for you. See the FAQ for more details.
    Nov 2007
    thanks a lot, I will try it out and let you know. another thing forgot to ask. will it work for 4 LEDs or two? e.g. two front two rear...
    Nov 2007
  1. RX TX modules - intermitent communication
    Last Post: - 11th June 2009, 00:13
  2. pic16f88 & voltage
    By rdxbam in forum mel PIC BASIC Pro
    Last Post: - 17th February 2009, 09:14
  3. Ghange code from PIC16F877A to PIC16F88
    Last Post: - 12th March 2008, 16:09
  4. Replies: 8
    Last Post: - 7th December 2006, 15:42
  5. PIC16F88 problem with TOGGLE command?
    By russman613 in forum mel PIC BASIC Pro
    Last Post: - 17th September 2006, 23:31
