DIP switch select delay
Results 1 to 16 of 16
    Nov 2007
    Default DIP switch select delay
    HI, I'm a beginner in PIC, I want to do a simple counter project using DIP switch to select Delay, the small project is actually working already with 2 x 7 segment display.. but I need a selectable startup delay.But I dunno how to do it.. keeps failing!
    here is what I wanted..
    dip1=on, dip2=on, dip3=on, dip4=on == 8secs delay
    dip1=on, dip2=off, dip3=off, dip4=off == 7secs delay
    dip1=on, dip2=on, dip3=off, dip4=off == 6secs delay
    dip1=off, dip2=off, dip3=off, dip4=off == 5secs delay
    and so on...
    I've attach a example sch.
    maybe you guys might know some reference code or similar(PICBASIC)I can view?
    Thanks!
    Oct 2003
    holland
    If dip1 = 1 and dip2 = 1 and dip3 = 1 and dip4 = 1 then
    pause 8000
    if dip1 = 0 etc.
    or
    something var byte
    something = porta &%00111100
    if something = 60 then
    pause 8000
    if something = etc.
    It might help if someone knew what DIL 18 was.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    it's a 18 pins device with a DIL package I'll bet it's a black one
    Default Might not be black
    Some are dark brown. Some even have writing on them - I wonder what this one is?
    Another clueless student trying to fudge a class project by the looks of it.
    Nov 2007
    Yes it's 16F88 .. and it's 18pin... BLACK in color comes with some wording on top of it!! but I use my finger's to rub it off anyway.. and now it's unknown chips , so I put DIL18
    Thanks mat janssen , this is what I've done first... I'm sure somewhere must have coded wrongly.. I'll check tonite again!
    Thanks!
    Something like this is where LOOKUP2 comes in handy.
        @ DEVICE PIC16F88, WDT_OFF,INTRC_OSC,MCLR_OFF,BOD_ON,LVP_OFF,PWRT_ON,PROTECT_OFF
        DEFINE  OSC 8
        DEFINE  NO_CLRWDT 1
        OSCCON  = %01110000 ' 8MHz
        CMCON   = 7	        ' disable analog comparators
        ANSEL   = 0         ' disable A/D module, all digital
        X VAR WORD
        Index VAR BYTE
        LED VAR PORTB.0
        TRISA = %00111100   ' RA2 to RA5 inputs for DIP switch
        PORTB   = 0
        TRISB   = %11111110 ' RB0 for LED
        OPTION_REG = %11111111
        WHILE OSCCON.2 = 0  ' wait for internal osc stable before moving on
        WEND
        Index = (PORTA >> 2) & $0F ' Read DIP switch AND mask result
        LOOKUP2 Index,[200,300,400,500,600,700,800,900,1000,2000,_
        3000,4000,5000,6000,7000,8000],X
        HIGH LED
        PAUSE X
        LOW LED
        PAUSE X
        GOTO Main
    Change the delay periods in the table to suite your app.
    -Bruce
    tech at rentron.com
    Nov 2007
    Thanks Bruce!
    your code helps alot, and it looks much simpler then what I've done... thanks again!
    Hi Bruce,
    If I get this right . . translates to portA / 4 & %00001111 , what I do not get is what it means, are we doing math here to get a number ??? & = AND. What does it mean, Mask result?
    I am really trying to get my head around how this works, because it works pretty sweet, Thanks
    JS
    The OP show switch connected on RA<5:2>
    >>2 : yes it's divide by 4... but also easier to figure out when you use the 'Shift it 2 positions to right' term. Here it will shift the whole PORTA reading, 2 bits to the right... hence remove PORTA<1:0>
    the & $0F is indeed a Bitwise AND. This way it keep only bits <3:0>... here PORTA<5:2> once shifted to the right.
    Index=                  %10101111
    Index=Index >>2   ' now %00101011
    Index=Index & $0F ' now %00001011
    Thank You Mister_e,
    I will have to think on this awhile, but I see it throws out the 2 LSB and then throws out the 4 MSB, seems odd, I just have to get my thick head around it. Would it be possible to use say PortB and use only 4 ports in BCD fashion while using the rest as outputs? Something like
    Index = PORTB<3:0>?
    JS
    Hi Joe,
    It's a lot simpler than it might look at first glance.
    By shifting the value read in from the 8-bit porta register right by 2, we're just shifting the 4-bits of interest into the lower 4-bits of the Index variable. Next we AND the intermediate result with %00001111 so the Index variable can never be larger than 15.
    We do this because the lookup table has 16 entries. 0 to 15.
    LOOKUP2 Index,[200,300,400,500,600,700,800,900,1000,2000,3000,400 0,5000,6000,7000,8000],X
    If Index = 0 then 200 is placed in X. If Index = 15 then X = 8000.
    If you used RA0 to RA3 for the switches you wouldn't need to shift right by 2 since the switches would be connected to the lower 4-bits of the port. You would still want to AND the result with %00001111 however just to make sure the result in Index never exceeded 15 since the lookup table only has 16 entries. 0 to 15.
    You could of course use portb or any other port with at least 4 inputs for your switches.
    Say you already had the lower 4-bits of portb being used for something else, and you added 4 switches to RB4 to RB7.
    You could do something like Index = (PORTB >> 4) & $0F for the same effect we had above with the lookup table by limiting the result to
    0 - 15.
    If you use RB0 to RB3 for the switch inputs, then Index = PORTB & $0F is all you would need. The & $0F just makes sure Index stays within range by masking out the upper 4-bits.
    -Bruce
    tech at rentron.com
    Thanks Bruce !
    Now I Get It !
    Thanks Also To Mister_e
    Thanks Bruce !
    Now I Get It !
    I'd save the pins, and use an old pot and the POT command, if tight accuracy wasn't needed anyways.
    Save the pins, possibly save some code space, most likely save some PCB space.
    I thought about that, I really want to port this over to a 12F675 for a dedicated gadget. That is why I asked about using the other pins as outputs . . . so much to learn . . . so many cool tricks . . . so many Giving Caring Wonderful people . . . My Thanks!
    JS
    AND, the POT command doesn't require an analog capable pin.
    Bonus points...
  1. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 07:57
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 15:23
  3. RF Transmitter
    By et_Fong in forum mel PIC BASIC Pro
    Last Post: - 27th October 2005, 16:34
  4. Memory Space of the PIC16F84...
    By Tear in forum mel PIC BASIC Pro
    Last Post: - 1st July 2005, 19:55
  5. Problem with saving to EEPROM...
    Last Post: - 1st July 2005, 00:10
