Button problem driving me crazy!! Please help!
Results 1 to 12 of 12
    Lightbulb
    Hi Bearpawz,
    I just tried your code on a 16F628 and it worked just fine. You probably have a hardwareproblem. Check and make sure that your outputs are swinging all the way between 0 and Vdd, if not you're in trouble. Most common mistake is a missing(or to low) resistor in series with the LED. You also need to make sure that your pulldownresistors(on the buttons) are properly connected. Other shorts could ofcourse also be a problem.
    Even though ive been through every circuit on the board with a meter and found no problems, Im thinking it must be hardware as well. Im going to see if I can find the right style switch in a push on/push off configuration and just hook up supply power to that switch (the way it should be done anyway). thanks for the help though.
  1. PBP is driving me crazy trying to make an 18F chip blink
    By George in forum mel PIC BASIC Pro
    Last Post: - 20th June 2008, 07:08
  2. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
  3. Code check -- button not working
    Last Post: - 2nd March 2006, 23:43
  4. push button problem
    Last Post: - 2nd June 2005, 20:44
  5. Button problem.
    By Modena in forum mel PIC BASIC Pro
    Last Post: - 5th November 2004, 17:43
