Button problem driving me crazy!! Please help!
Results 1 to 12 of 12
    I had already thought of that and tried programming with all that stuff disabled. Ive put "test" lines of code in here and there and its acting like it wants to excute BOTH parts of the if-thenelse statement.
    Jan 2006
    Istanbul
    Hi there,
    There are couple of things you did not specify in your code.
    1. You set your OSC to be 8Mhz (internal OSC) but you are declaring it to PBP as 20Mhz. Are you using internal OSC or external OSC?
    2. Since you did not enable internal weak pull ups on PORTB pins, I assume you are using external pull up resistors on your input buttons. If you are not using any, then input pins may behave like crazy.
    3. This chip has analog port on PORTA. You have a speaker on PORTA.0 but you did not disable analog module.
    4. "If Power_LED = 1 ..." this won't work. You can not read the state of an output pin. I suggest that you set a flag bit and read that flag instead.
    Quote Originally Posted by sayzer View Post
    Hi there,
    1. OSCON is recycled code, I commented it out. However I am programming it to use HS in the config bit so it shouldn’t really matter... (?)
    2. Weak pull ups are not enabled but the hardware uses cookie cutter schematic example from PBP manual under the "Button" command. Pin is held low Via 10K resistor until pushed, then goes high.
    3. I haven’t even bothered with the port a stuff yet. Its basically just sending a DTFMOUT command when a button is pressed.
    4. "IF POWER LED = 1 Then..", It actually DOES work. In fact, there is absolutely no issues with that line of code at all. I tested it by simply not turning on the power LED. When Power LED is off it does not execute the if/then statement; only when it is on. Either way, I’ve tried using a simple 1 bit flag and it didn’t resolve anything.
    Here are the lines of code in question with my notes as to what’s happening:
    Start:
    If Power = 1 Then Power_Pressed <----- Only branch to power pressed if button pushed
    'If Power_LED = 1 then ' Execute only if in ON state
    ' If Normal = 1 Then Normal_Pressed ' Normal button pressed?
    ' If Pursuit = 1 Then Pursuit_Pressed ' Pursuit button Pressed?
    ' If Auto = 1 then auto_pressed ' Auto button pressed
    'EndIF
    Goto Start ' Loop forever
    Power_Pressed: <---- Should only be here when power pressed. This part seems fine until...
    If Power_LED = 1 Then <--- Check to see if we are on of off by looking at power LED
    Low Power_LED ' Turn off Power LED
    Low Auto_LED ' Turn off Auto LED
    Low Normal_LED ' Turn off Normal LED
    low Pursuit_LED ' Turn off Pursuit LED
    pause 1000 ' 1 second denounce delay
    Right here is the problem. At this point what will happen is the unit goes into (simulated) power off mode and waits for 1 second. That at least confirms the code is working, and the swtich should have had ample time to no longer be in a pushed state. And the above block does indeed do what it is supposed to when it is supposed to.
    So at this point we should be jumping over everything in the ELSE statement and going directly back to start. Instead, it executes everything in the else statement.
    High Power_LED ' Turn on Power_LED
    High Normal_LED ' Turn on Normal_LED
    Pause 1000 ' 1 Second Debounce delay
    Goto Start
    What I have done to try and resolve this is: use a flag instead of directly reading the pin: there was no change. I’ve added test code to confirm that the unit is executing the code in the "else" section as opposed to just restarting the program. I have even tried putting in Repeat/until loops to check for the button being 0 again and then being 1. I’m starting to think the think is just possessed. Everything else works exactly the way it is supposed to. I’ve tried the same code testing different switches... It all boils down to this one if/then/else statement that SHOULD work.
    Just for complete fun, I decided to go back and re-add a flag instead of reading the port directly. It had no effect. I even went as far as trying a brand new chip (16F818 instead of 819) and it still does the same exact thing. here is the NEW code: And I’m just totally stumped.
    DEFINE OSC 20 ' 20 Mhz Oscillation
    'OSCCON = $70 ' Oscilator Config reg.
    Clear ' Clear all memory
    TRISA = %00000000 ' Set port a to all out
    TRISB = %00001111 ' Set Port b to i/o
    Speaker Var PortA.0 ' Tone pin out
    Power Var PortB.0 ' Input for power switch
    Auto VAR PortB.1 ' Input for Auto Switch
    Normal VAR PortB.2 ' Input for Normal Switch
    Pursuit VAR Portb.3 ' Input for Pursuit Switch
    Power_LED VAR Portb.7 ' Output for Power Lamp
    Auto_LED Var Portb.6 ' Output for Auto Lamp
    Normal_LED VAR Portb.5 ' Output for Normal Lamp
    Pursuit_LED VAR Portb.4 ' Output for Pursuit Lamp
    Power_Flag Var bit ' Flag to indicate power on/off
    Initialize:
    High Power_LED ' Power Default = ON
    low Auto_Led ' Auto Defualt = OFF
    High Normal_LED ' Normal Default = ON
    low Pursuit_LED ' Pursuit Default = ON
    Power_Flag = 1 ' Unit is on, set power flag
    Start:
    If Power_Flag = 1 then ' Execute only if in ON state
    If Pursuit = 1 Then Pursuit_Pressed ' Pursuite button Pressed?
    EndIF
    '**************************SUBROUTINE AREA********************************
    Auto_Pressed: ' Auto button code:
    Low Pursuit_LED ' Turn off Pursuit lamp
    Low Normal_LED ' Turn off Normal Lamp
    High Auto_LED ' Turn on Auto Lamp
    'DTMFOUT Speaker, [1] ' Send tone sound out
    Goto start ' Go back to main routine
    Normal_Pressed: ' Normal button code:
    Low Auto_LED ' Turn off Auto Lamp
    High Normal_LED ' Turn on Normal Lamp
    Goto Start ' Go back to main routine
    Pursuit_Pressed: ' Pursuit button code:
    High Pursuit_LED ' Turn on Pursuit Lamp
    Power_Pressed:
    If Power_Flag = 1 Then
    pause 1000 ' debounce delay
    Power_Flag = 0 ' Falgged for off state
    Pause 1000 ' Debounce delay
    Power_Flag = 1 ' Flagged for on state
    Goto Start
    untested but i figure i would change the following section...
            PowerOn var bit
    Initialize:
            poweron = 1
    Start:
            If poweron = 1 then' Execute only if in ON state
            Goto Start ' Loop forever        '
    Power_Pressed:
            If poweron = 1 Then
                poweron=0
                pause 1000 ' 1 second debounce delay
                    poweron=1
            Goto Start
    deuh.. looks the same thing you've done... weird... it has to work.
    insert those config fuse at the top of your code..
            asm
            list w=-207
            cfg1 = _HS_OSC & _MCLR_OFF & _CCP1_RB2 & _BODEN_ON & _PWRTE_ON &_WDT_OFF
            cfg2 = _LVP_OFF & _DEBUG_OFF & _CP_OFF & _WRT_ENABLE_OFF & _CPD_OFF
            list w=+207
            __CONFIG cfg1 & cfg2
            endasm
    Bombay, India
    Its more a manner of style I presume, but, here's how I prefer to configure the device
    @  device  HS_OSC, MCLR_OFF, PWRT_ON, WDT_OFF
    @  device  PROTECT_ON,BOD_ON, CPD_ON
    To understand these defines, look at the M16F81x.INC file. They are all listed there.
    Excerpted from the file
    					; *** DEVICE Fuses Definitions
    EXTRC_OSC_CLKOUT equ    3FEC0013h       ; XX XXXX XXX1 XX11
    EXTRC_OSC_NOCLKOUT equ  3FEC0012h       ; XX XXXX XXX1 XX10
    EXTRC_OSC       equ     3FEC0012h       ; XX XXXX XXX1 XX10
    INTRC_OSC_CLKOUT equ    3FEC0011h       ; XX XXXX XXX1 XX01
    INTRC_OSC_NOCLKOUT equ  3FEC0010h       ; XX XXXX XXX1 XX00
    INTRC_OSC       equ     3FEC0010h       ; XX XXXX XXX1 XX00
    EXTCLK_OSC      equ     3FEC0003h       ; XX XXXX XXX0 XX11
    EC_OSC          equ     3FEC0003h       ; XX XXXX XXX0 XX11
    HS_OSC          equ     3FEC0002h       ; XX XXXX XXX0 XX10
    XT_OSC          equ     3FEC0001h       ; XX XXXX XXX0 XX01
    LP_OSC          equ     3FEC0000h       ; XX XXXX XXX0 XX00
    WDT_ON          equ     3FFB0004h       ; XX XXXX XXXX X1XX
    WDT_OFF         equ     3FFB0000h       ; XX XXXX XXXX X0XX
    PWRT_ON         equ     3FF70000h       ; XX XXXX XXXX 0XXX
    PWRT_OFF        equ     3FF70008h       ; XX XXXX XXXX 1XXX
    MCLR_ON         equ     3FDF0020h       ; XX XXXX XX1X XXXX
    MCLR_OFF        equ     3FDF0000h       ; XX XXXX XX0X XXXX
    BOD_ON          equ     3FBF0040h       ; XX XXXX X1XX XXXX
    BOD_OFF         equ     3FBF0000h       ; XX XXXX X0XX XXXX
    LVP_ON          equ     3F7F0080h       ; XX XXXX 1XXX XXXX
    LVP_OFF         equ     3F7F0000h       ; XX XXXX 0XXX XXXX
    CPD_ON          equ     3EFF0000h       ; XX XXX0 XXXX XXXX
    CPD_OFF         equ     3EFF0100h       ; XX XXX1 XXXX XXXX
    WRT_1FOURTH     equ     39FF0000h       ; XX X00X XXXX XXXX
    WRT_HALF        equ     39FF0200h       ; XX X01X XXXX XXXX
    WRT_3FOURTHS    equ     39FF0400h       ; XX X10X XXXX XXXX
    WRT_OFF         equ     39FF0600h       ; XX X11X XXXX XXXX
    DEBUG_ON        equ     37FF0000h       ; XX 0XXX XXXX XXXX
    DEBUG_OFF       equ     37FF0800h       ; XX 1XXX XXXX XXXX
    CCPMX_ON        equ     2FFF0000h       ; X0 XXXX XXXX XXXX
    CCPMX_OFF       equ     2FFF1000h       ; X1 XXXX XXXX XXXX
    PROTECT_ON      equ     1FFF0000h       ; 0X XXXX XXXX XXXX
    PROTECT_OFF     equ     1FFF2000h       ; 1X XXXX XXXX XXXX
    I think this makes it independent of whether you use MPASM or PM assembler.
    Yup, but i NEVER use PM, it's way to limited when you compare with MPASM function set. AND it work for ALL pic family, from 10f to pic32
    The right syntax for MPASM would be..
    @    __CONFIG _HS_OSC & _MCLR_OFF & _CCP1_RB2 & _BODEN_ON & _PWRTE_ON &_WDT_OFF & _LVP_OFF & _DEBUG_OFF & _CP_OFF & _WRT_ENABLE_OFF & _CPD_OFF
    but it's way too long, why i've splitted in 2 lines. LIST directive is just to remove mpasm warning... label found in colum 1... really annoying stuff.
  1. PBP is driving me crazy trying to make an 18F chip blink
    By George in forum mel PIC BASIC Pro
    Last Post: - 20th June 2008, 07:08
  2. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
  3. Code check -- button not working
    Last Post: - 2nd March 2006, 23:43
  4. push button problem
    Last Post: - 2nd June 2005, 20:44
  5. Button problem.
    By Modena in forum mel PIC BASIC Pro
    Last Post: - 5th November 2004, 17:43
