Button problem driving me crazy!! Please help!
Results 1 to 12 of 12
    Default Button problem driving me crazy!! Please help!
    The info:
    Using a pic 16F819, 20MHZ crystal oscilator
    What I am trying to do:
    I have 4 momentary pushbuttons with coresponding lamps. One is a "power" switch / lamp, the rest are one of three (ie, push one button and its lamp comes on, the others go off).
    The "one of three" part works flawlessly.
    My problem lies in the "Power" button. The unit defaults with power on and one other lamp lit. When I press the power switch, I want all lamps to go out until power switch is pressed again. (Simulating turn the whole unit off). For the LIFE of me I can not figure out what is going on with my code. Its not a debounce issue, ive tried puting in delays up to 10 seconds after the button is pressed and the unit insists on going back to the power up state. here is the code:
    DEFINE OSC 20 ' 20 Mhz Oscillation
    OSCCON = $70 ' Oscilator Config reg.
    Clear ' Clear all memory
    TRISA = %00000000 ' Set port a to all out
    TRISB = %00001111 ' Set Port b to i/o
    Speaker Var PortA.0 ' Tone pin out
    Power Var PortB.0 ' Input for power switch
    Auto VAR PortB.1 ' Input for Auto Switch
    Normal VAR PortB.2 ' Input for Normal Switch
    Pursuit VAR Portb.3 ' Input for Pursuit Switch
    Power_LED VAR Portb.7 ' Output for Power Lamp
    Auto_LED Var Portb.6 ' Output for Auto Lamp
    Normal_LED VAR Portb.5 ' Output for Normal Lamp
    Pursuit_LED VAR Portb.4 ' Output for Pursuit Lamp
    Initialize:
    High Power_LED ' Power Default = ON
    low Auto_Led ' Auto Defualt = OFF
    High Normal_LED ' Normal Default = ON
    low Pursuit_LED ' Pursuit Default = ON
    Start:
    If Power = 1 Then Power_Pressed
    If Power_LED = 1 then ' Execute only if in ON state
    If Normal = 1 Then Normal_Pressed ' Normal button pressed?
    If Pursuit = 1 Then Pursuit_Pressed ' Pursuite button Pressed?
    If Auto = 1 then auto_pressed ' Auto button pressed
    EndIF
    Goto Start ' Loop forever
    '**************************SUBROUTINE AREA********************************
    Auto_Pressed: ' Auto button code:
    Low Pursuit_LED ' Turn off Pursuit lamp
    Low Normal_LED ' Turn off Normal Lamp
    High Auto_LED ' Turn on Auto Lamp
    'DTMFOUT Speaker, [1] ' Send tone sound out
    Goto start ' Go back to main routine
    Normal_Pressed: ' Normal button code:
    Low Auto_LED ' Turn off Auto Lamp
    High Normal_LED ' Turn on Normal Lamp
    Goto Start ' Go back to main routine
    Pursuit_Pressed: ' Pursuit button code:
    High Pursuit_LED ' Turn on Pursuit Lamp
    Power_Pressed:
    If Power_LED = 1 Then
    Low Power_LED ' Turn off Power LED
    Low Auto_LED ' Turn off Auto LED
    Low Normal_LED ' Turn off Normal LED
    low Pursuit_LED ' Turn off Pursuit LED
    pause 1000 ' 1 second debounce delay
    High Power_LED ' Turn on Power_LED
    High Normal_LED ' Turn on Normal_LED
    Pause 1000 ' 1 Second Debounce delay
    Goto Start
    Bombay, India
    Just thinking aloud; I haven't checked the datasheet for the device. Is your watchdog kicking in and resetting the device?
    Jerson
    I had already thought of that and tried programming with all that stuff disabled. Ive put "test" lines of code in here and there and its acting like it wants to excute BOTH parts of the if-thenelse statement.
    Jan 2006
    Istanbul
    Hi there,
    There are couple of things you did not specify in your code.
    1. You set your OSC to be 8Mhz (internal OSC) but you are declaring it to PBP as 20Mhz. Are you using internal OSC or external OSC?
    2. Since you did not enable internal weak pull ups on PORTB pins, I assume you are using external pull up resistors on your input buttons. If you are not using any, then input pins may behave like crazy.
    3. This chip has analog port on PORTA. You have a speaker on PORTA.0 but you did not disable analog module.
    4. "If Power_LED = 1 ..." this won't work. You can not read the state of an output pin. I suggest that you set a flag bit and read that flag instead.
    Quote Originally Posted by sayzer View Post
    Hi there,
    1. OSCON is recycled code, I commented it out. However I am programming it to use HS in the config bit so it shouldn’t really matter... (?)
    2. Weak pull ups are not enabled but the hardware uses cookie cutter schematic example from PBP manual under the "Button" command. Pin is held low Via 10K resistor until pushed, then goes high.
    3. I haven’t even bothered with the port a stuff yet. Its basically just sending a DTFMOUT command when a button is pressed.
    4. "IF POWER LED = 1 Then..", It actually DOES work. In fact, there is absolutely no issues with that line of code at all. I tested it by simply not turning on the power LED. When Power LED is off it does not execute the if/then statement; only when it is on. Either way, I’ve tried using a simple 1 bit flag and it didn’t resolve anything.
    Here are the lines of code in question with my notes as to what’s happening:
    Start:
    If Power = 1 Then Power_Pressed <----- Only branch to power pressed if button pushed
    'If Power_LED = 1 then ' Execute only if in ON state
    ' If Normal = 1 Then Normal_Pressed ' Normal button pressed?
    ' If Pursuit = 1 Then Pursuit_Pressed ' Pursuit button Pressed?
    ' If Auto = 1 then auto_pressed ' Auto button pressed
    'EndIF
    Power_Pressed: <---- Should only be here when power pressed. This part seems fine until...
    If Power_LED = 1 Then <--- Check to see if we are on of off by looking at power LED
    pause 1000 ' 1 second denounce delay
    Right here is the problem. At this point what will happen is the unit goes into (simulated) power off mode and waits for 1 second. That at least confirms the code is working, and the swtich should have had ample time to no longer be in a pushed state. And the above block does indeed do what it is supposed to when it is supposed to.
    So at this point we should be jumping over everything in the ELSE statement and going directly back to start. Instead, it executes everything in the else statement.
    Goto Start
    What I have done to try and resolve this is: use a flag instead of directly reading the pin: there was no change. I’ve added test code to confirm that the unit is executing the code in the "else" section as opposed to just restarting the program. I have even tried putting in Repeat/until loops to check for the button being 0 again and then being 1. I’m starting to think the think is just possessed. Everything else works exactly the way it is supposed to. I’ve tried the same code testing different switches... It all boils down to this one if/then/else statement that SHOULD work.
    Just for complete fun, I decided to go back and re-add a flag instead of reading the port directly. It had no effect. I even went as far as trying a brand new chip (16F818 instead of 819) and it still does the same exact thing. here is the NEW code: And I’m just totally stumped.
    'OSCCON = $70 ' Oscilator Config reg.
    Power_Flag Var bit ' Flag to indicate power on/off
    Initialize:
    Power_Flag = 1 ' Unit is on, set power flag
    Start:
    If Power_Flag = 1 then ' Execute only if in ON state
    EndIF
    Power_Pressed:
    If Power_Flag = 1 Then
    pause 1000 ' debounce delay
    Power_Flag = 0 ' Falgged for off state
    Pause 1000 ' Debounce delay
    Power_Flag = 1 ' Flagged for on state
    Goto Start
    untested but i figure i would change the following section...
            PowerOn var bit
    Initialize:
            poweron = 1
    Start:
            If poweron = 1 then' Execute only if in ON state
            Goto Start ' Loop forever        '
    Power_Pressed:
            If poweron = 1 Then
                poweron=0
                    poweron=1
            Goto Start
    deuh.. looks the same thing you've done... weird... it has to work.
    Quote Originally Posted by bearpawz View Post
    The info:
    Hi Bearpawz,
    You did not say what your circuit <b>IS</b> doing, or not doing. Since you are pulling PortB.0 up to signal your PIC, I ask if you remembered to pull it down with a resistor to logic low so as not to have a high impeadance on that pin? Lemmie guess, a controller for a dual purpose or B/W, yes?
    JS
    EDIT: WOW Sayzer slipped in just ahead of me ! Hi Sayzer !
    Lightbulb
    Hi Bearpawz,
    I just tried your code on a 16F628 and it worked just fine. You probably have a hardwareproblem. Check and make sure that your outputs are swinging all the way between 0 and Vdd, if not you're in trouble. Most common mistake is a missing(or to low) resistor in series with the LED. You also need to make sure that your pulldownresistors(on the buttons) are properly connected. Other shorts could ofcourse also be a problem.
    Even though ive been through every circuit on the board with a meter and found no problems, Im thinking it must be hardware as well. Im going to see if I can find the right style switch in a push on/push off configuration and just hook up supply power to that switch (the way it should be done anyway). thanks for the help though.
  1. PBP is driving me crazy trying to make an 18F chip blink
    By George in forum mel PIC BASIC Pro
    Last Post: - 20th June 2008, 07:08
  2. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
  3. Code check -- button not working
    Last Post: - 2nd March 2006, 23:43
  4. push button problem
    Last Post: - 2nd June 2005, 20:44
  5. Button problem.
    By Modena in forum mel PIC BASIC Pro
    Last Post: - 5th November 2004, 17:43
