PWM PIN(S), DUTY, CYCLE ?Plural possible?
Results 1 to 4 of 4
    Sep 2005
    Campbell, CA
    This is probably a silly question, but if you are attempting to drive two pins with the same signal, at the same time and the same phase, why do you need TWO pins?
    Charles Linquist
    Jan 2007
    Houston, TX
    Default 2 pins
    As I stated, I am driving 2 seperate h-bridges...each bridge has 2 inputs. I have a total of 4 inputs to both h-bridges and want to always drive 2 pins at any one time.
    if I want my robot to turn right I need to drive
    'ex: not actual code...
    rightwheelfw var portb.0
    rightwheelrs var portb.1
    leftwheelfw var portb.2
    leftwheelrs var portb.3
    turnright:
    high rightwheelrs
    high leftwheelfw
    pause 50
    goto commands
    turnleft:
    high rightwheelfw
    high leftwheelrs
    pause 50
    goto commands
    In my case though I want to have variable speed control not just HIGH.
    This is why I want PWM on 2 pins at the same time.
    Padawan-78
    there's some PIC which give you 2 different CCP module and allow that.
    There's also some PIC with ECCP (even a 12F615), which can be used to drive in half bridge/Full bridge mode + few feature such as dead band time. 18F2431/4431 are some good example.
    http://ww1.microchip.com/downloads/e...Doc/39616C.pdf
    depending your expected PWM frequency, Darrel's Muti_SPWM could be used
    http://www.pbpgroup.com/modules/wfse...p?articleid=12
    Timer interrupt is another way to go.
  1. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  2. Replies: 9
    Last Post: - 8th October 2008, 12:15
  3. HPWM the old fashioned way
    By Srigopal007 in forum mel PIC BASIC Pro
    Last Post: - 19th November 2004, 20:09
  4. PWM _ Duty Cycle in Tenths
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 17th May 2004, 13:09
  5. Duty Cycle Dilemmas
    By crankshaft in forum mel PIC BASIC Pro
    Last Post: - 27th February 2003, 13:40
