LCD setup
Results 1 to 12 of 12
Thread: LCD setup
    Hi nomad,
    i think i know what's going on !
    the thing is that i moved the stardard configuration to give me the RA0 and RA1 free and use them for analog input.
    I have my code set for all PORTa to be input and analog...dahhh ( therefore the lcd RS to pic RA4 is not working )
    TRISA = %11111111 ' Set PORTA to all input
    ADCON1 = %10000010 ' Set PORTA analog and right justify result
    This is why it doesnt work.
    I need to set ONLY PORTA 0 and 1 ports analog and not all.
    I will remove the first line ( trisa = %1111111 ) because it doesnt make any sense.
    About the second line : ADCON = %10000010...
    how can i set only RA0 and RA1 analog and the rest of the portA digital ?
    thanks
    You need the TRISA line. each bit determines input or output. so if you want ra4 as an output you need to change trisa to %11101111 also need cmcon=7 to disable the comparators. I dont have a data sheet to see what you need for adcon1 but the analog is for input only, and doesn't apply to a pin set to output. (as far as i understand) i think the cmcon and trisa lines should do the trick.
    you may have some problem with 16F628 and ADCON1... as it don't have any a/d converter.
    While it's always a good programming practice to set TRIS register, LCDOUT do it for you.
    Faulty i/o
    No contrast pot on LCD Vo line
    R/W pin not tied to GND
    no pull-up (~10K) on OpenCollector output
    floating MCLR input if used, or not disabled in code
    same thing for LVP mode,
    faulty/missing connections
    unsufficient LCD startup time
    are some things to check.
    Didn't know that about lcdout. Learn something new each day lol. That explains why i couldn't remember the settings for adcon1. Thanks MisterE.
    Thank you all for the help.
    I started again from scratch and did some experiments moving the RS and E lines arround and all worked fine.
    Now i have to sucessfully move the data bus to Portb.
    I did not have the time yet to do so, but i will keep this thread updated.
    In other hand, i've just realised that i will not able to finish this project because the 16F628 does not have the A/D converter i need to measure temp. - seen the analog input and assumed that it also had A/D :s ( Thanks Mister_E ).
    Have to go and buy some 16F88s.
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. Need help with LCD number display.
  4. LCD will not start
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 15:44
