LCD setup
Results 1 to 12 of 12
Thread: LCD setup
    Default LCD setup
    Hi guys,
    i'm changing my lcd wires from the stardard configuration but i'm not getting this to work ( maybe it's too late and cant think right ) !!!
    The idea is to:
    lcd RS to pic RA4
    lcd E to pic RB4
    lcd DB to pic RB0,RB1,RB2,RB3
    i'm using these defines:
    Define LCD_DREG PORTB
    Define LCD_DBIT 0
    Define LCD_RSREG PORTA
    Define LCD_RSBIT 4
    Define LCD_EREG PORTB
    Define LCD_EBIT 4
    thanks
    you show RS on pin ra4 but define says rsbit 3. also typically ra4 is open collector or open drain as an output and will need a pullup resistor. which pic are you using?
    hey no fair you changed it while i was posting. lol. ok so that leaves the pullup issue.
    hehehe...
    sorry nomad,
    right now i'm slow thinking, but i got there
    i'm using a 16F628.
    Also have a pullup 100K resistor...but still not working...
    100k might be to large. too weak a pullup. i usually see 10k or even 4.7k as the pullup. check your input/output trisA settings and disable comparators, cmcon=7? ra4 is tied to cmp2.
    oh yeah, also make sure the R/W line isn't left floating. needs to be grounded i believe. did you set 4 bit mode? DEFINE LCD_BITS 4. thats all i can think of without having the data sheet here or seeing the code. hope that helps.
    Last edited by nomad; - 17th November 2007 at 02:15. Reason: weeee too late to think.
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. Need help with LCD number display.
    Last Post: - 27th June 2007, 00:07
  4. LCD will not start
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 15:44
