pls help me
Results 1 to 2 of 2
Thread: pls help me
    london's Avatar
    london Guest
    Default pls help me
    hi,
    I am using 24LC640 EEPROM (SPI). I want the memory organization mapping of this device. I cant find it from the data sheet. I want the starting and ending addresses. Pls anyone tell me with example.
    thanks in advance
    jeya
    it sure start @ 0, and Section 3.2 state
    Quote Originally Posted by Section 3.2
    When the highest address is
    reached (1FFFh), the address counter rolls over to
    address 0000h allowing the read cycle to be continued
    indefinitely.
    now, if we use the calc.. it's a 64K device, (64K/8Bits)*1024 = 8192 memory allocation range, so 0 to 8191, 8191= 1FFFh
    <hr>
    for the code, you'll need to use Shiftin/Shiftout. do a search within the forum for 93C06, 93c45, SPI* maybe you'll find something to begin. Also have a look at the following from Melabs.
    http://melabs.com/resources/samples/x1/pbp/spix.bas
    All device command are shown in the datasheet, sure you can do it.
  1. sms to control pic..pls help...
    By Ziki in forum mel PIC BASIC Pro
    Last Post: - 12th April 2010, 21:19
  2. guys pls help me in mp lab
    By darylbrown2005 in forum mel PIC BASIC
    Last Post: - 9th March 2009, 16:58
  3. Help me pls
    Last Post: - 7th March 2009, 18:40
  4. Unable to compile..Pls Help
    By DragonBall_6 in forum mel PIC BASIC Pro
    Last Post: - 8th October 2008, 15:17
  5. How to decode IR Hitachi remate (TV) pls help
    Last Post: - 4th March 2006, 11:55
