16f877a
Results 1 to 16 of 16
Thread: 16f877a
    Nov 2007
    Default thanks
    What i only see in my pbp directory is the pbpw.exe file could be a problem with
    the installing disc. Its a disc i get from a friend who did not need it any more
    and for me it was a good to see if it was better to program in picbasic
    but without that 16f877a.bas file i cant do nothing and buying again that program
    without knowing it will work is to expensive, is the 16f877a.bas the only file im missing then?
    Thanks very much
    Dirk
    No. You will need a great deal more than just pbpw.exe and a .bas header file.
    That's what is so nice about actually purchasing legal copies. You get full support, and a
    compiler that actually works.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Nov 2007
    Default thanks
    I gues it is a legal, but there is something wrong with the disc i guess,
    thats probaply why he give it to me but the only thing is nnow that i catnt
    test it
    Thanks very much
    Dirk
    If you can't get the files you need from your friend so you have the full working version, you
    can still test drive the compiler. Just download the demo. It supports the 877A.
    http://www.microengineeringlabs.com/pbpdemo.htm
    Read the yellow section on this page http://www.microengineeringlabs.com/...pgrade.htm#pbp
    -Bruce
    tech at rentron.com
    Nov 2007
    Default i did
    but i dont see any 877a.bas files.
    The demo version is a bit different, and does not install the same files. Run it, and try it.
    -Bruce
    tech at rentron.com
    Nov 2007
    Default ok i will:)
    ill try i tommorow, but important is for me that it works with the ICD MPLAPS
    see tomorrow
    dirk
  1. 16F877 vs. 16F877A
    By DavyJones in forum General
    Last Post: - 11th April 2009, 19:22
  2. help my bluetooth and PIC 16F877A?
    By slimpeng in forum mel PIC BASIC Pro
    Last Post: - 18th March 2008, 07:52
  3. Read the newbee threads, 16F877A no go.
    By BobbyA in forum mel PIC BASIC Pro
    Last Post: - 31st December 2006, 04:09
  4. Clock connection to DS1802 from 16F877A
    By coyotegd in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2006, 19:52
  5. 1st 16F877A program in PICBasic
    By Borisw37 in forum mel PIC BASIC Pro
    Last Post: - 19th January 2005, 05:46
