16f877a
Results 1 to 16 of 16
Thread: 16f877a
    Nov 2007
    Default 16f877a
    I use microchip MPLab ICD 2 and the picfem 2 plus board, now im complete new to this
    so i tried to program in picbasi waht moer familiar looks to me, i set the pbpw as compiler
    now when i use a bas program , and compile the message always is:
    ERROR: Unable to find -p<pic> processor file
    doe any knows whats wrong? i looked on the web for 16F877A.BAS file
    buth did not found it. Im getting nervous of this
    Thanks any way
    Here is he sample program:
    '* MICROCODE STUDIO TIPS *
    '* (1) : To get context sensitive help, move your cursor to a PICBasic *
    '* : command and then press F1. *
    '* (2) : Program assumes the PIC is running at 4MHz. To change the default *
    '* : setting (for example, to 20MHz) simply add DEFINE OSC 20 at the *
    '* : top of your program. *
    '* This sample program is supplied courtesy of microEngineering Labs Inc *
    ' PicBasic Pro program to display result of
    ' 8-bit A/D conversion on LCD
    ' Connect analog input to channel-0 (RA0)
    Define LCD_DREG PORTD
    Define LCD_DBIT 4
    Define LCD_RSREG PORTE
    Define LCD_RSBIT 0
    Define LCD_EREG PORTE
    Define LCD_EBIT 1
    adval var byte ' Create adval to store result
    ADCON1 = %00000010 ' Set PORTA analog and LEFT justify result
    ADCON0 = %11000001 ' Configure and turn on A/D Module
    Pause 500 ' Wait .5 second
    loop:
    ADCON0.2 = 1 ' Start Conversion
    notdone:
    Pause 5
    If ADCON0.2 = 1 Then notdone ' Wait for low on bit-2 of ADCON0, conversion finished
    adval = ADRESH ' Move high byte of result to adval
    Lcdout $fe, 1 ' Clear screen
    Lcdout "Value: ", DEC adval ' Display the decimal value
    Pause 100 ' Wait .1 second
    Goto loop ' Do it forever
    And what have you got in the way of software? You did purchase a PBP Compiler... it doesn't come free with your ICD2...
    Nov 2007
    Default 16f877a
    I purchased it but i wanna use mplab cd2 because it was delivered with my picdem board
    Nov 2007
    Default no much help in here:(
    There's lots of help here, but you need to be a tad more specific.
    Are you compiling from within MPLAB or MicroCode Studio?
    Do you have MPASM or PM selected as the assembler?
    Which version of PBP do you have?
    Have you looked in your PBP install directory?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Nov 2007
    Default more details
    hope someone can help me im trying nos for 2 weeks
    but thank already for the reply.
    Im compiling within MPLAB
    I have selected the PBPW as the assembler
    procompiler 2.46
    16F877A.BAS is not in my pbp directory
    no
    Support for the 877A was added back in version 2.42. If you can't find 16F877A.BAS in your
    PBP directory, then you should re-install, or contact the distributor you purchased PBP from.
    They should be able to help you if there are missing device header files on your original PBP
    install disc.
    PBPW is not the assembler. It's the Windows version of the compiler EXE. In MPLAB, with PBP
    setup as the language tool, you have the option of selecting PM or MPASMWIN as the
    assembler.
    But you will need to get familiar with MPLAB if you're compiling PBP programs using this IDE.
    Assuming you have installed PBP correctly (as shown in your PBP manual), you have the path
    setup, and PBP setup properly within MPLAB, you should not have any problems getting it to
    compile in MPLAB.
    You might find this page helpful http://www.microengineeringlabs.com/support/mplab.htm
    -Bruce
    tech at rentron.com
    Nov 2007
    Default thanks
    What i only see in my pbp directory is the pbpw.exe file could be a problem with
    the installing disc. Its a disc i get from a friend who did not need it any more
    and for me it was a good to see if it was better to program in picbasic
    but without that 16f877a.bas file i cant do nothing and buying again that program
    without knowing it will work is to expensive, is the 16f877a.bas the only file im missing then?
    Thanks very much
    Dirk
    No. You will need a great deal more than just pbpw.exe and a .bas header file.
    That's what is so nice about actually purchasing legal copies. You get full support, and a
    compiler that actually works.
    -Bruce
    tech at rentron.com
    Nov 2007
    Default thanks
    I gues it is a legal, but there is something wrong with the disc i guess,
    thats probaply why he give it to me but the only thing is nnow that i catnt
    test it
    Thanks very much
    Dirk
    If you can't get the files you need from your friend so you have the full working version, you
    can still test drive the compiler. Just download the demo. It supports the 877A.
    http://www.microengineeringlabs.com/pbpdemo.htm
    Read the yellow section on this page http://www.microengineeringlabs.com/...pgrade.htm#pbp
    -Bruce
    tech at rentron.com
    Nov 2007
    Default i did
    but i dont see any 877a.bas files.
    The demo version is a bit different, and does not install the same files. Run it, and try it.
    -Bruce
    tech at rentron.com
    Nov 2007
    Default ok i will:)
    ill try i tommorow, but important is for me that it works with the ICD MPLAPS
    see tomorrow
    dirk
    I don't think you will be able to run ICD2 without ICDDEFS.BAS which is required to reserve
    ICD resources. Like any demo, there are limitations as compared to the full version.
    You can however use the ICD2 as a device programmer with no problem.
    -Bruce
    tech at rentron.com
    raptor's Avatar
    raptor Guest
    Default Demo works fine with ICD 2 and Picdem 2 Plus
    I'm using the PB Pro demo with MPlab 8.0 using Mpasmwin and ICD2 and the Picdem 2 Plus(older version 2002). The only problem I had was a path problem. I'm using a 16F877 and it gave some message about finding the P16F877.inc file. I setup my path for PB pro and the mpasmwin directories but it didn't help. So for a temp solution, copied, then modified the 16F877.inc file with the full path. Works great now.
    ;* 16F877.INC *
    ;* Notice : Copyright (c) 2004 microEngineering Labs, Inc. *
    ;* All Rights Reserved *
    ;* Date : 03/12/04 *
    ;* Version : Demo *
    ;* Notes : *
    NOLIST
    ifdef PM_USED
    LIST
    include 'M16F87x.INC' ; PM header
    device pic16F877, xt_osc, wdt_on, pwrt_on, lvp_off, protect_off
    XALL
    NOLIST
    LIST
    LIST p = 16F877, r = dec, w = -302
    INCLUDE "C:\Program Files\Microchip\MPASM Suite\P16F877.INC" ; MPASM Header
    __config _XT_OSC & _WDT_ON & _PWRTE_ON & _LVP_OFF & _CP_OFF
    NOLIST
    LIST
    Other than that the demo works fine and you will find that 31 commands is a big limitation. I liked the demo, so I order the full version today, hopefully MElabs are a fast shipping company.
    Jerry
  1. 16F877 vs. 16F877A
    By DavyJones in forum General
    Last Post: - 11th April 2009, 19:22
  2. help my bluetooth and PIC 16F877A?
    By slimpeng in forum mel PIC BASIC Pro
    Last Post: - 18th March 2008, 07:52
  3. Read the newbee threads, 16F877A no go.
    By BobbyA in forum mel PIC BASIC Pro
    Last Post: - 31st December 2006, 04:09
  4. Clock connection to DS1802 from 16F877A
    By coyotegd in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2006, 19:52
  5. 1st 16F877A program in PICBasic
    By Borisw37 in forum mel PIC BASIC Pro
    Last Post: - 19th January 2005, 05:46
