Efficient Fixed-Point Trigonometry For PIC16F
Results 1 to 13 of 13
    looking at the asm... i'm aware that my asm skills sucks, but, i don't understand why they used the line in red...
    ATAN
    	banksel	   _Z_H				; Z_H & Z_L is loaded with 0x0000
    	movlw		0x00				; Y & X is the input
    	movwf		_Z_H				; X(i+1)	=	Xi - Yi*_Di*2^-i
    	movlw		0x00				; Y(I+1)	=	Yi + Xi*_Di*2^-i
    	movwf		_Z_L				; Z(i+1)	=	Zi - _Di*ATAN(2^-i)
    	banksel	   _Di					; _Di		=	1 if Yi < 0 ELSE _Di	=	0
    	bsf		      RV					; Set Vectoring Mode
    	goto		CORDIC_Alg
    SINCOS
    	banksel	   _Y_L				; Z_H & Z_L is the input
    	movlw		0x00				; Y_H & Y_L is loaded with 0x0000
    	movwf		_Y_L				; X_H & X_L is loaded with 6070 (1/An constant)
    	movlw		0x00
    	movwf		_Y_H
    	movlw		LOW .6070
    	movwf		_X_L				; X(i+1)	=	Xi - Yi*_Di*2^-i
    	movlw		HIGH .6070		; Y(I+1)	=	Yi + Xi*_Di*2^-i
    	movwf		_X_H				; Z(i+1)	=	Zi - _Di*ATAN(2^-i)
    	banksel	   _Di					; _Di		=	0 if Zi < 0 ELSE _Di	=	1
    	bcf		      RV					; Set Rotational Mode
    w already hold 0x00 and they reload it again for the next MOVWF? BTW i would use CLRF instead... no big deal, it remove 4 instructions... long run, it may decrease a little bit the calculation latency. OK OK no big improvement, but... i couldn't resist. maybe i'll find something else?
    so, once modified, the above code section should look like...
    ATAN
    	CHK?RP	_Z_H		; Z_H & Z_L is loaded with 0x0000
    	clrf	_Z_H		; X(i+1) = Xi - Yi*_Di*2^-i
    	clrf	_Z_L		; Z(i+1) = Zi - _Di*ATAN(2^-i)
    	CHK?RP	_Di		; _Di	 = 1 if Yi < 0 ELSE _Di	= 0
    	goto	CORDIC_Alg
    SINCOS
    	CHK?RP	_Y_L		; Z_H & Z_L is the input
    	clrf	_Y_L		; X_H & X_L is loaded with 6070 (1/An constant)
    	clrf	_Y_H
    	movlw	LOW .6070
    	CHK?RP	_Di		; _Di	 = 0 if Zi < 0 ELSE _Di	= 1
    But yeah, i think we're not at the optimization stage yet
    Default Cordic Trig Include file for PIC16
    Looks great! Good catch.
    Here is a paste able version of the code to integrate into picbasic. (just takes up about 180 words). It loads the bytes needed for assembly. It uses X_ Y_ and Z_ word variables to load the bytes needed for the assembly routine.
    '*  Name    : trig-pic16.inc                                    *
    '*  Author  : Walter Dunckel                                    *
    '*  Notice  : Copyright (c) 2009 Scale Robotics Inc.            *
    '*  Date    : 9/6/2011                                          *
    '*  Version : 2.1                                               *
    '*  Notes   : Consolodated some variables to save ram and space *
    '* to convert degrees to radians Z_ * 256 / 90                  *
    '* to convert radians to degrees Z_ * 90 / 256                  *
    '* to perform ATAN, enter values for X_ and Y_ :                *
    '* X_ = 12631                                                   *
    '* Y_ = 11881                                                   *
    '* call ATAN                                                    *
    '* 'result will be in Z_ radians = 134                          *
    '* Z_ * 90/256 = 47 degrees                                     *
    '* To find the result of Cos and Sin:                           *
    '*Z_ = 90                    'put angle in Z_ in degrees        *
    '*Z_ = (Z_ * 255)/90     'convert degrees to radians            *
    '*call SINCOS                 'perform sin and cos on Z_ value  *
    '* 'results will be located here: cos(Z_) = X_ :sin(Z_) = Y_    *
    '* in thousandths, for instance 9999 ~ 1.000                    *
    'more info: http://www.picbasic.co.uk/forum/showthread.php?t=7502
    'and PIC18 version http://www.picbasic.co.uk/forum/showthread.php?t=10528
    X_          var     word bank0
    Y_          var     word bank0
    Z_          var     word bank0
    X_H         VAR     X_.byte1
    X_L         VAR     X_.byte0
    Y_H         VAR     Y_.byte1
    Y_L         VAR     Y_.byte0
    Z_H         VAR     Z_.byte1
    Z_L         VAR     Z_.byte0
    X_TMP_H     VAR     byte bank0
    X_TMP_L     VAR     byte bank0
    Y_TMP_H     VAR     byte bank0
    Y_TMP_L     VAR     byte bank0
    ITERAT_TMP  VAR     byte bank0
    ITERATION   VAR     byte bank0
    Di          VAR     byte bank0
    COSCH       VAR     byte bank0
    COSCL       VAR     byte bank0
    Counter1    VAR     byte bank0
    SHIFT       VAR     byte bank0
    goto jump_trig
    asm
    ;__________________________________________________________________________
    FSR_ptr macro addr
           CHK?RP          addr
           bcf             STATUS,IRP
           btfsc           STATUS,RP1
           bsf             STATUS,IRP
           movlw           LOW addr
           movwf           FSR
           #define     Dir _Di,0
           #define     RV          _Di,1
           #define     _C          STATUS,0
           #define     _Z          STATUS,2
    Z_stepH_tbl
           addwf   PCL,f
           dt      0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
    Z_stepL_tbl
           addwf   PCL,f
           dt      0x80,0x4C,0x28,0x14,0x0A,0x05,0x03,0x01
    Z_NstepH_tbl
           addwf   PCL,f
           dt      0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF
    Z_NstepL_tbl
           addwf   PCL,f
           dt      0x80,0xB4,0xD8,0xEC,0xF6,0xFB,0xFD,0xFF
    _ATAN
           clrf            _Z_H            ; Y & X is the input
           clrf            _Z_L            ; X(i+1)    =   Xi - Yi*_Di*2^-i
           goto            CORDIC_Alg
    _SINCOS
           clrf            _Y_L     ; Y_H & Y_L is loaded with 0x0000
           clrf            _Y_H     ; X_H & X_L is loaded with 6070 (1/An constant)
           movlw           LOW .6070
    CORDIC_Alg
           CHK?RP          _ITERATION
           clrf            _ITERATION
    Rotation_loop
    BUFF_X_Y                          ; Buffers both X & Y into temporary registers
           CHK?RP          _Y_L
           movf            _Y_L, W    ; Move Y --> T_TEMP
           movwf           _Y_TMP_L
           movf            _Y_H, W
           movwf           _Y_TMP_H
           movf            _X_L, W    ; Move Y --> T_TEMP
           movwf           _X_TMP_L
           movf            _X_H, W
           movwf           _X_TMP_H
           CHK?RP          _Di            ; Vectoring or Rotational Mode?
           bcf             Dir
           btfsc           RV
           goto            Rot
    Vec
           btfss           _Z_H, 7    ; Determine the state of _Di (1 OR -1)
           bsf             Dir    ; _Di=1 when Z_H is pos
           goto            Cordic
    Rot
           btfsc           _Y_H, 7    ; Determine the state of _Di (1 OR -1)
           bsf             Dir    ; _Di=1 when Y_H is neg
    Cordic
           movfw           _ITERATION
           movwf           _SHIFT     ; Load number of shifts
           bsf             _SHIFT,7 ; Shift right (Division)
           FSR_ptr         _Y_TMP_L       ; Load FSR
           call            Shifter    ; Execute shift
           btfsc           Dir
           call            COM_YTEMP  ; Get the 2's complement of teh TEMP register
    SUM_X                             ; Calculate X(i+1)
           movf            _Y_TMP_H, W
           addwf           _X_H, F
           movf            _Y_TMP_L, W
           addwf           _X_L, F
           btfsc           _C
           incf            _X_H, F
           movfw           _ITERATION
           FSR_ptr         _X_TMP_L                ; Load FSR
           btfss           Dir
           call            COM_XTEMP  ; Get the 2's complement of teh TEMP register
    SUM_Y                                          ; Calulate Y(i+1)
           movf            _X_TMP_H, W
           addwf           _Y_H, F
           movf            _X_TMP_L, W
           addwf           _Y_L, F
           btfsc           _C
           incf            _Y_H, F
           btfss           Dir
           goto            ADD_Z
           movlw           HIGH Z_NstepH_tbl
           movwf           PCLATH
           movfw           _ITERATION       ; Fetch appropriate value from table
           call            Z_NstepH_tbl
           addwf           _Z_H, F
           movlw           HIGH Z_NstepL_tbl
           movwf           PCLATH
           movfw           _ITERATION
           call            Z_NstepL_tbl
           addwf           _Z_L, F
           btfsc           _C
           incf            _Z_H, F
           goto            Rot_Loop_out
    ADD_Z
           movlw           HIGH Z_stepL_tbl
           movwf           PCLATH
           movfw           _ITERATION
           call            Z_stepH_tbl
           addwf           _Z_H, F
           movlw           HIGH Z_stepH_tbl
           movwf           PCLATH
           movfw           _ITERATION
           call            Z_stepL_tbl
           addwf           _Z_L, F
           btfsc           _C
           incf            _Z_H, F
    Rot_Loop_out
           incf            _ITERATION,f
           btfsc           _ITERATION,3
           goto            Rotation_loop
    COM_YTEMP
           comf            _Y_TMP_L, F             ; Complememt Y_TMP
           comf            _Y_TMP_H, F
           movlw           01H
           addwf           _Y_TMP_L, F
           btfsc           _C
           incf            _Y_TMP_H, F
    COM_XTEMP
           comf            _X_TMP_L, F             ; Complememt X_TMP
           comf            _X_TMP_H, F
           movlw           01H
           addwf           _X_TMP_L, F
           btfsc           _C
           incf            _X_TMP_H, F
    Shifter                        ; Function for shifting 16bit signed REG i times
           CHK?RP          _SHIFT      ;  left/right MUL/DIV
           movfw           _SHIFT      ; INPUTS: FSR & IRP are pointing to LOW REG
           andlw           0x0F        ; SHIFT = d000 XXXX where XXXX = # of shifts
           btfsc           _Z          ;       and d = dir of shift
           return                      ; check for zero interations
           movwf           _Counter1
           btfss           _SHIFT,0x7
           goto            CORDIC_MUL
    CORDIC_DIV
           rrf             INDF, F   ; Divide INDF/2 INDF --> low byte
           bcf             INDF, 7
           decf            FSR, F
           rrf             INDF, F
           incf            FSR, F
           btfsc           _C
           bsf             INDF, 7   ; Carry from the upper byte to the lower byte
           decf            FSR, F
           bcf             INDF, 7 ;Check to see if TEMP should be positive number
           btfsc           INDF, 6
           bsf             INDF, 7 ;Was a negative number, force it negative again
           incf            FSR, F
           decfsz          _Counter1, F
           goto            CORDIC_DIV
    CORDIC_MUL
           bcf             _C
           rlf             INDF, F
           decf            FSR, F
           rlf             INDF, F
           bcf             INDF, 7
           btfsc           _C
           bsf             INDF, 7
           incf            FSR, F
           decfsz          _Counter1, F
           goto            CORDIC_MUL
    ;______________________________________________________________________________
    endasm
    jump_trig:
    Last edited by ScaleRobotics; - 7th September 2011 at 18:09. Reason: Cleared up code a little, and added description
    Then you can do some pretty cool stuff!
    Like find the bearing to and distance to a lat-lon waypoint (solving for latitude adjustment of Longitude!)
    Here is my ugly code. Needs to be cleaned up ... but it works for waypoints that are within 3.2000 degrees of eachother (200 miles or so). Angle still needs to be corrected depending which quadrant the waypoint lies.
    DEFINE __16F877A 1				; list directive to define processor
    DEFINE OSC 20                          ' Define Oscillator Speed
    DEFINE LOADER_USED 1
    ' Shutdown comparators
    ADCON1 = 7                        ; Turn of all A/D
    CMCON  = 7
    ' Set the port directions
    ' 0=output 1=input
    TRISA=%00000011                         ' Set PORTA  0-1-3 used for AD
    TRISB=%11011100                         ' Set PortB
    TRISC=%10000000
    TRISD=%00000000                       ' Set PortC USART RX as an input
    porta.2 = 0
    porta.3 = 0
    X_          var     word
    Y_          var     word
    Z_          var     word
    X_H         VAR     byte
    X_L         VAR     byte
    Y_H         VAR     byte
    Y_L         VAR     byte
    Z_H         VAR     byte
    Z_L         VAR     byte
    X_TMP_H     VAR     byte
    X_TMP_L     VAR     byte
    Y_TMP_H     VAR     byte
    Y_TMP_L     VAR     byte
    ITERAT_TMP  VAR     byte
    ITERATION  VAR      byte
    Di          VAR     byte
    COSCH       VAR     byte
    COSCL       VAR     byte
    Counter1    VAR     byte
    SHIFT       VAR     byte
    x           var     word
    y           var     word
    z           var     word
    i           var     word
    lon_dif     var     word
    lat_dif     var     word
    angle       var     word
    angle_deg   var     word
    distance    var     word
    j           var     word
    ;---------[change these to match your hardware]------------------------------
    DEFINE LCD_DREG PORTD             ; Set LCD Data port                B C   D
    DEFINE LCD_DBIT 0                 ; Set starting Data bit (0 or 4)   4 0
    DEFINE LCD_RSREG PORTA            ; Set LCD Register Select port     A A
    DEFINE LCD_RSBIT 3                ; Set LCD Register Select bit      3 2
    DEFINE LCD_EREG PORTA             ; Set LCD Enable port              A A
    DEFINE LCD_EBIT 1                 ; Set LCD Enable bit               1 5
    DEFINE LCD_BITS 4                 ; Set LCD bus size (4 or 8 bits)   4 4
    DEFINE LCD_LINES 2                ; Set number of lines on LCD       2 2
    clear
    lcdout $FE,1
    lcdout $FE,1,"Test"
    ' to convert degrees to radians Z_ * 256 / 90
    ' to convert radians to degrees Z_ * 90 / 256
    Start:
    x = 0
    y = 0
    z = 37              'input current latitude 37.xxx for longitude correction (lon smaller at higher latitude)
    lat_dif = 11881         'difference between current position and waypoint in latitude 1.1881 deg
    lon_dif = 15816         'difference between current position and waypoint in longitude 1.5816 deg
    i = z * 256 / 90        'changes z to the right format +256 to -256
    'each 1/3 degree should equal about 1 radian need to figure out how to get this accuracy......
    if (z*256)//90 >= 45 then i = i +1        'if answer is .5 or more, go to next highest integer (round number)
    Z_ = i                    'put result in Z_
    Call sincos
    i = X_ * lon_dif        ' X_ = cos(lat_current)
    lon_dif = div32 10000      ' get the value of lon_dif * the fraction for lon correction (reduces lon_dif)
    X_ = lon_dif 'load lon_dif into X_ , prepare for ATAN function
    Y_ = lat_dif 'load lat_dif into Y_ , prepare for ATAN function
    call atan                        'perform ATAN assembly function
    angle = Z_
    angle_deg = Z_ *90/256          'puts angle in degrees into the variable
    'Below code computes distance between waypoints
    'Z_ is already loaded with angle from above result
    call sincos
    i = lon_dif * 10000         'get lon_dif ready to divide by fraction
    distance = div32 X_       'divide by cos(Z_)gives latitude distance in d.dddd or really ddddd
    distance = distance * 69  'get miles units
    distance = div32 100      'hundreths of miles    xx.xx miles
    lcdout $FE,1,#distance
    lcdout $FE,$C0,#angle_deg 'not corrected for quadrant, ie. + 180, or + 90, etc. only bare triangle angle
    end '***********************************
    Dec 2008
    For anyone interested, the latest code was posted by Scalerobotics here:
    http://sites.picbasic.net/index.php?...d=91&pageid=62
    (the downloads don't seem to be working right now)
    I believe the 16 bit code as posted on the above link did need the following minor tweaks:
    Instead of:
    lathome_min = lathome_min + 33*((((gpsdata[char_A+4] -48)*1000)+((gpsdata[char_A+5]-48)*100)+((gpsdata[char_A+7]-48)*10)+(gpsdata[char_A+8]-48))*5)//3
    However, I believe it should read as follows so that the modulus is calculated first:
    lathome_min = lathome_min + 33*(((((gpsdata[char_A+4] -48)*1000)+((gpsdata[char_A+5]-48)*100)+((gpsdata[char_A+7]-48)*10)+(gpsdata[char_A+8]-48))*5)//3)
    Second:
    latdest_min = latdest_min + (tempbyte*33) 'use remainder and add to latdest_min
    should read as follows:
    latdest_min = latdest_min*5/3 + (tempbyte*33) 'use remainder and add to latdest_min
