Some help needed (newb content)
Results 1 to 4 of 4
    Sep 2009
    Default Some help needed (newb content)
    Hello,
    Ok, I've been programming in Ass for a while, and now have seen the light.
    Simple prog to flash an led if a button is pressed.
    Code follow:
    @ DEVICE pic16F819
    @ DEVICE INTRC_OSC_NOCLKOUT
    @ DEVICE CPD_OFF
    Define OSC 8 'Osciallator 8Mhz
    OSCCON=112 'INT OSC 8 MHZ
    ADCON0 = 0
    CCP1CON = %00000000 'Turn comparators off
    Trisa=%00000001 'Sets PortA RA0 and RA1 as ip rest as output.
    CoolHeat Var PORTA.0 'Switch IP High=flash
    RL1 Var PORTA.1 'Relay output
    Start:
    If CoolHeat=0 THen 'button not pressed
    HIGH RL1
    If Coolheat=1 Then 'button pressed flashes LED
    high rl1
    Low RL1
    Pause 500
    high rl1
    Low RL1
    Pause 500
    Endif
    goto Start
    The switch is pulled up via 4k7 to Vcc. LED has 330r in series.
    When I power up the led is on as it should be, switch is open.
    When I pull RA.0 high the led *should* flash but does not.
    Any ideas?
    Many thanks.
    Lightbulb
    May be you forgot one I/O config line ...
    ADCON1 i.e.
    Sep 2009
    All sorted,
    loose power connection to PIC plus added the code detailed.
    Full steam ahead now!
    Mar 2009
    Colorado
    Default Need to also set RA1 as input
    Quote Originally Posted by Woogle View Post
    Your Trisa statement only sets RA0 as in input. Your comment says you want to also set RA1 as input. Therefore you need TRISA = %00000011 .
  1. ASCII Viewer Needed
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 19th January 2008, 06:29
  2. Programers Needed Still !
    By picawiner in forum mel PIC BASIC Pro
    Last Post: - 5th June 2007, 14:51
  3. Newbee Hardware PWM clarification needed
    By emmett brown in forum General
    Last Post: - 9th July 2006, 10:18
  4. Circuit needed to allow a PIC to turn something on or off
    Last Post: - 12th October 2005, 22:17
