Serin2 pass through to Serout2
Results 1 to 6 of 6
    try this
            '       PIC Configuration
            @ __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BODEN_ON
                    ' Internal Oscillator
                    ' Enable watch dog timer
                    ' Enable power up timer
                    ' Disable MCLR pin
                    ' Enable brown out detect
            DEFINE OSCCAL_1K 1      ' load internal osc calibration
            '       Hardware configuration
            TRISIO = %00101010      ' set GP3, GP4, GP5 input
                                    ' others to output
            ANSEL = 0               ' disable adc
            CMCON = 7               ' disable comparators
            '       Hardware assignment
            S_In1   var GPIO.1      ' Serial input #1
            S_In2   VAR GPIO.5      ' Serial input #2
            S_Out   VAR GPIO.4      ' Serial output
            '       Variables definition
            Command VAR BYTE[10]
            Baud    var word
            '       Constants definition
            T2400   CON 396
            T4800   CON 188
            T9600   CON 84
            N2400   CON 16780
            N4800   CON 16572
            N9600   CON 16468
            '       Software/Hardware initialisation
                    '       select baudrate
            baud = t9600
                    '       Set serial output pin idle level
            if baud<400 then
                high s_out
                    low s_out
            pause 50            ' settle time
            serout2 s_out,baud,["Hello, this is a test!!!",13,10]
            '       Program Start
    Start:
            serout2 s_out,baud,["i'm waiting for incoming data on GPIO.1",13,10]
            serin2  s_in1,baud,[str command\10\13]
            Serout2 s_out,baud,["i got...", str command,13,10,13,10,_
                                "waiting for some data on GPIO.5",13,10]
            Serout2 s_out,baud,["i got...", str command,13,10,13,10]
            goto    start
    Mar 2005
    Steve,
    Thanks for your time! I will try this when I get home this evening.
    4) there's no max-232 (or else inverter) between the PIC and the PC
    Sorry forgot to mention the PIC connects to a Bluetooth radio then to the PC. This has been a stable product of ours for the last 1 1/2 years. This is a test for our customer adding the IButton. Both sides are direct connect!
    Scott
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 22:14
  2. Serout and 18F87J50
    By Glenn_Webber in forum Serial
    Last Post: - 20th November 2009, 14:26
  3. SLOW Serin2 and Serout2
    By dragons_fire in forum General
    Last Post: - 26th June 2009, 02:38
  4. SEROUT2 and SERIN2 commands
    By bangunprayogi in forum mel PIC BASIC Pro
    Last Post: - 4th August 2005, 09:03
  5. Simple PC Menu System with Serin2
    Last Post: - 3rd April 2005, 08:27
