Program to convert & send eeprom dump!!!
Results 1 to 7 of 7
    Question Program to convert & send eeprom dump!!!
    This is maybe off topic but is there any existing program to take an EEPROM dump (.bin, .hex...) from a PC an send it by COM port??? I know that can be done easily but why reinvent the wheel???
    many regards to all of you.
    Dec 2003
    Wichita KS
    Hello Mister-e,
    M>>This is maybe off topic but is there any existing program to take an EEPROM dump (.bin, .hex...) from a PC an send it by COM port??? I know that can be done easily but why reinvent the wheel???<<
    Lets first get this straight.... Are you wanting to take data from your computer and transfer it to the PIC chip? or Take data from the PIC chip and transfer it to the computer?
    Either way, PBP has serial communication that you can do data transfer with... Both directions. You may have to go at a slow baud rate...2400 or less (probably 300 for solid reliablity). I have used the old Procomm communication program for dos, to send/receive data to the PIC chip.
    If this is not in the general direction of your question, I am sorry... I guess I misunderstood your quesiton.
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    Hi Dwayne,
    the goal of it is to update eeprom attach to an existing PIC Based project by software. Since we are able to update software of PIC by ICSP why not include a hidden function to update eeprom connected to it if it need to.
    So i can edit my eeprom dump with the usual software on computer, save it to disk, and after it send it to PIC who will update the eeprom.
    Sorry if i was not really clear in my questions.
    thanks for help.
    regards
    Dec 2003
    Wichita KS
    Hello Mister-e,
    Ok, then (if I understand correctly). Lets write a simple program to so such..
    DEFINE CHAR_PACING 1000 '1 millisecond between characters.
    Send Routine
    ReadData var byte
    For a = 0 to (length of EEPROM) step 1
    Read ReadData
    Serout PinX, ReadData, T300
    Next a
    'another kind of send routine useing FF for done with sending.
    Send Routine
    ReadData var byte
    Counter var byte
    Counter=0
    ReadData=1
    while ReadData!=FF
    Read Counter, ReadData
    Counter =Counter + 1
    Wend
    Receive Routine
    ReadData=1
    Counter var byte
    Counter=0
    while ReadData != 255 'flag for end of transmission
    Serin PinX, ReadData, T300
    Write Counter, ReadData 'write data to EEPROM
    Counter=Counter + 1 'next EEPROM place
    Wend
    Now to trigger these routines, its up to you... Maybe look for a pin toggle? Or use a special sequence... like
    Serin Pinx, ReadData, ["XYZ"],DataRead
    if DataRead="T" gosub Transmit_routine
    if DataRead="R" gosub Receive_routine
    goto where_ever you want to go for no good pin.
    The transmit and Recieve code I wrote above has not been tested, but I would not be surprised if it is very close to the correct code you may be looking for.
    Dwayne
    Ability to Fly:
    Hi Dwayne,
    he he, i'm ok for the PIC software, what i need is a PC software to send the file (.BIN) already on hard disk to the COM port. That's it!!!.
    your code seems to be o.k. but i really apologize if i wasn't enough clear this time. I already find RealTerm wich seems to be O.K. If not i will probably build my own in VB.
    thanks for reply. Any other idea are welcome.
    regards
    Dec 2003
    Wichita KS
    Then you would want Procomm for DOS, it is shareware/freeware. It will do just about anything you want to do with a COM port...Hyerterminal (which comes with windows) would work too, but its not as elaborate.
    Dwayne
    Ability to Fly:
    Hi Dwayne,
    i get this DOS based ProComm program and it seems to work well like RealTerm. They are both do the job for me now.
    I see also that the newest version is now provide by Symantec... why not??? i'll try to find on share place like Limewire or in worst case dumb Kazaa bulsh... site.
    Thanks for help. I'll do mine anyway since i want more specific function for future project. The only thing i need is a couple of free hours to do it as i want. Everybody understand what i mean :0) Free time... is somebody have it???
    many regards
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  2. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 04:17
  3. Data EEPROM gets clobbered during programming
    Last Post: - 18th July 2008, 03:46
  4. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 07:26
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 20:59
