POT and RCTIME instructions
Results 1 to 5 of 5
    Wink Very good exercise ...
    Hi, Trent
    I think it's a very good exercise for our friend to discover how awful the POT function is ,
    and with RCTime, the use of retrieving tables ( lookup + linearization ).
    but we must keep in mind there's no issue to read temps with better accuracy than 1°C, if we do not use any calibration ...
    Even a MS 5534 ( that is factory calibrated ! ) is given for a +/- .8 °C accuracy ...
    The LM 335 is given for a CALIBRATED +/- .5 °C error ...
    and do not talk abot the NTC's ( +/- 10 to 20% on nominal value @ 25°C )
    Platinum std probes offer 1% ...
    So, no need to look for high tech measurements for a ... 7 bits accuracy !!!
    Hi all,
    thanks for the tips.
    I have here a datasheet for the LM35.
    The LM335 also looks very good.
    I dont mind the 1ºC resolution, but i guess i will change my pic for one with ADC.
    In your opinion what pic is more alike with the 16F84 but with ADC capability ?
    PIC16F88, PIC16F819 are nices and have internal OSC, which gives you 2 free i/o (or 3 if you don't use MLCR).
    2-3 i/o for free, is a real nice bonus.
    If you don't need anything timing critical (serial comm or else), no external OSC is also
    1) time saver
    2) cost saver
    3) PCB space saver
    come on... forget the stone-age and almost 10 years outdated 16F84
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  2. reading the value of a pot
    By studysession in forum mel PIC BASIC Pro
    Last Post: - 1st February 2009, 10:45
  3. Pic Basic TouchScreen? How?
    By mindthomas in forum General
    Last Post: - 15th April 2008, 17:53
  4. I'm getting strange Results using POT or RCTIME on PortB (or GPIO Port)
    Last Post: - 15th July 2004, 21:01
  5. POT Command
    By Acetronics2 in forum mel PIC BASIC Pro
    Last Post: - 5th May 2004, 17:54
