driver amps
Results 1 to 3 of 3
Thread: driver amps
    May 2007
    Default driver amps
    hi folks,
    I have a 18V 3A cordless drill motor. I want to mod it for a servo application. The bigger driver I found is a SN754410 which covers up to 36V...Ok, but only 1A.
    If using them of course identically: Is it possible to connect 3 of theese IC's so to sum its amps 1A + 1A + 1A to my motor ?
    "Beethoven had his critics too, see if you can name 3 of them"
    Aug 2005
    An L6203 H-bridge might do it for you.Its good up to 48v and 4amps.But you must attach it to a good heat sink or it will fry.
    May 2007
    thank you arnie for the info,
    i got surprised when I discovered that the motor was really a 18V 12Amps!!!, then I got to know that such kind of application is better in the dirty way... with mosfets and all that stuff,
    Anyway the info you gave me is usefull for another proyect I have in mind, thxs!
  1. MCP3208 12 bit A/D driver
    By polymer52 in forum Code Examples
    Last Post: - 5th February 2010, 12:59
  2. Help with LED driver fade on/off
    By dfort in forum mel PIC BASIC Pro
    Last Post: - 25th July 2009, 01:39
  3. 3 Digit LCD and Driver IC
    By ClayE in forum mel PIC BASIC Pro
    Last Post: - 16th August 2008, 07:45
  4. Measuring Volts and Amps digitally
    Last Post: - 15th July 2008, 17:21
  5. MM5451 35way LED driver example
    By J_norrie in forum Code Examples
    Last Post: - 12th May 2008, 10:16
