Use Button For setup
Results 1 to 15 of 15
    Nov 2007
    Unhappy
    Thanks tried your suggestion but still not working.
    When save = 1
    I want it to exit the loop and resume running the program, am I missing something obvious, or not so obvious since I am new at this ???
    Maybe it is a debounce problem. Add a "PAUSE" at the beginning of "loop".
    loop:
    PAUSE 250 'Give a little time to get off the button
    if Setup = 1 then
    Nov 2007
    I am using an interrupt now I have pasted the whole code below in case i missed something with the interrupt.
    @ DEVICE PIC16F877A,HS_OSC
    DEFINE  debug_mode  0            ' Debug sending True serial data
    DEFINE  debug_reg portc          ' Debug Port = PortC
    DEFINE  debug_bit 6              ' Debug.bit = PortC.6
    DEFINE  debug_baud 9600          ' Default baud rate = 9600
    DEFINE  osc 8                    ' We're using a X MHz oscillator
    DEFINE  ADC_BITS 8               ' Set A/D for 8-bit operation
    DEFINE  ADC_CLOCK 3              ' Set A/D clock r/c
    DEFINE  ADC_SAMPLEUS 50          ' Set A/D sampling time @ 50 uS
    Define  LCD_DREG        PORTD    ' Define LCD pins
    Define  LCD_DBIT        4        'use upper 4 bits d4-d7
    Define  LCD_RSREG       PORTD
    Define  LCD_RSBIT       2
    Define  LCD_EREG        PORTD
    Define  LCD_EBIT        3
    DEFINE  LCD_LINES       2
    Define LCD_COMMANDUS 2000        ' Command Delay (uS)
    Define LCD_DATAUS 50	         ' Data Delay (uS)
    Fan VAR PortC.2
    Idle Var PortC.3
    Save    Var portc.1
    Incr    VAR portc.4              ' Increment button
    Decr    VAR portc.5              ' Decrement button
    Season VAR PORTB.1               ' 1=summer 0=winter
    AtticSamples    VAR WORD         ' Multiple A/D sample accumulator
    AtticSample     VAR BYTE         ' Holds number of samples to take
    GarageSamples   VAR WORD         ' Multiple A/D sample accumulator
    GarageSample    VAR BYTE         ' Holds number of samples to take
    AtticTemp       VAR BYTE         ' Attic Temperature storage
    GarageTemp      VAR Byte         ' Garage Temperature Storage
    Hysterisis      VAR BYTE         ' Hysterisis
    SetPoint        VAR BYTE         ' Temperature Setpoint
    SetPoint = 70
    AtticSamples = 0                 ' Clear samples accumulator on power-up
    GarageSamples = 0                ' Clear samples accumulator on power-up
    Hysterisis = 2
    TRISA = %11111111                ' Set PORTA to all input
    ADCON1 = %00000011               ' Set PORTA.0,1,2,5 = A/D, PortA.3 = +Vref
    TRISC.2 = 0
    intcon = %10010000               ' enable rbo interrupt
             PAUSE 500               ' Wait .5 second
    powerup:
    on interrupt goto SetSetPoint
         DEBUG "P",10,13
         LCDOUT $fe, 1, "Heat Circulator"
         LCDOUT $fe, $C0, "By Sonic"
         DEBUG "PowerUp",10,13
    loop:
        toggle Idle
        FOR Atticsample = 1 TO 20    ' Take 20 samples
            ADCIN 0, AtticTemp       ' Read channel 0 into AtticTemp variable
            Atticsamples = Atticsamples + Attictemp ' Accumulate 20 samples
            PAUSE 250           ' Wait approximately 1/4 seconds per loop
        Toggle Idle
        NEXT Atticsample
            Attictemp = Atticsamples/20
         Toggle Idle
        FOR Garagesample = 1 TO 20    ' Take 20 samples
            ADCIN 1, Garagetemp       ' Read channel 1 into GarageTemp variable
            Garagesamples = Garagesamples + Garagetemp ' Accumulate 20 samples
        Toggle Idle
        NEXT Garagesample
            Garagetemp = Garagesamples/20
          Toggle Idle
            Pause   100             ' Do it about 10 times a second
       ; If Garagetemp >= 70 then GOSUB TempOK
        If Season=0 THEN goSUB Winter
        If SEASON=1 THEN goSUb Summer
    TempOK:
    '** If temperature in garage is greater than or equal to SetPoint turn off ***
    '** circulator fan                                                         ***
           LCDOUT $fe, 1, "CirculatorOff ", #AtticTemp,"F" ' Send to LCD Line 1
           Lcdout $fe, $C0, "GarageTemp >= ",#SetPoint, #GarageTemp,"F" 'Send to LCD Line 2
                Fan = 0
            DEBUG "OK,",#SetPoint,"'","G",#GarageTemp,".","A",#AtticTemp,10,13
         Atticsamples = 0             ' Clear old sample accumulator
         Garagesamples = 0            ' Clear old sample accumulator
            goto loop
    Winter:
    ' if attic temp is greater than garage temp turn on ciculator fan
        If GarageTemp >= SetPoint then
        goto TempOK
        If AtticTemp > GarageTemp + Hysterisis Then
            Fan = 1
        Else
            Fan = 0                            'Turn OFF Fan Output
        GOTO Messages                                ' Do it forever
    Summer:
    ' if attic temp is less than garage temp turn on circulator fan
        If GarageTemp > SetPoint then
       goto TempOK
        If AtticTemp + Hysterisis < GarageTemp Then
          Fan = 1
        Else
          Fan = 0
    SetSetPoint:
     DISABLE
     LCDOut $FE,1,  "Setpoint at", #SetPoint, "F"
          if Incr = 1 then        'change the setpoint
              SetPoint=SetPoint+1
          if Setpoint>80 then SetPoint=60   'Allow setpoint from 60 to 80
             goto SetSetPoint               'refresh LCD with new setpoiont
           If Save = 0 then goto SetSetPoint
           LCDOut $FE,$C0,  "Saved Setpoint", #SetPoint, "F"
               Resume
              ENABLE
              goto loop
        LCDOUT $fe, 1, "Attic=", #AtticTemp,"F", "  ",#Season ' Send to LCD Line 1
        Lcdout $fe, $C0, "Garage=", #GarageTemp,"F", " ",#Fan 'Send to LCD Line 2
        DEBUG DEC AtticTemp,",", DEC GarageTemp,",",#fan,",",#Season,10,13
    GOTO Loop
    Rule #1: Keep Interrupt Service Routine as short as possible. in your ISR you don't want to use stuff like LCDOUT of spin inside 'till something happen. You check what you have to check, you set some variable/flags, and you get-out of there. In your main loop, or elsewhere, you wait and waste all time you want, as long as it's not going to messed the timer interrupt... unless you want to use Darrel's instant interrupts OR asm interrupts.
    Nov 2007
    Angry
    Thanks for the info, but this is the only way I can figure to get this done, I am having a hard enough time the basic way never mind asm interupts (I have not a clue on where to begin).
    Does this mean that this will not work due to the LCDout or did I make an error in writing the code.
    I dont know of any other way to do this, so If any one can give me a code example that would be greatly appreciated.
    Before the RESUME, try to clear the interrupt flag unless it will just get out of the ISR, then return there over and over....
    INTCON.1=0
    Maybe you'll need to implement some switch debouncing as well.
    Nov 2007
    Smile
    thanks for the info it works great now.
    But I have another question, why do I need to add this line I searched the manual and example and dont see INTCON used, did I do something wrong and this is a band aid ??
    I am trying to learn from my mistakes that is why I am asking
    Thumbs up
    You will find INTCON in the data sheet, section 2.2.2.3.
    INTCON.1=0 needs to be used, you have not done anything wrong. Basically this stops the interrupt and lets things continue.
    That is why this forum is so useful, we learn from each others mistakes
  1. Sony SIRC IR Issue
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 8th August 2015, 09:10
  2. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
  3. Code check -- button not working
    Last Post: - 2nd March 2006, 23:43
  4. Button Push within 3 second Window
    Last Post: - 22nd December 2005, 11:06
  5. Button subfunction 16F628
    By Jųan in forum mel PIC BASIC Pro
    Last Post: - 19th August 2005, 17:44
