ICSP Programming from a PDA
Results 1 to 3 of 3
    Nov 2007
    Melbourne, Australia
    Default ICSP Programming from a PDA
    Just wondering if anyone knows of any PIC Programming software for the Windows Mobile platform that supports ICSP a "JDM" style ICSP cable.
    I have tried WinPic800, ICProg, WinPIC, PICPgm - and although these all support my "RS232 to ICSP" JDM style cable, they also all require a Laptop to run.
    I would really like to find a way to use my PDA instead.
    Cheers,
    Ralph Parkhurst.
    Mar 2006
    China
    Default Not ICSP but almost
    Just put a bootloader in the pic and then program it using serialdata only. Then you dont even need a programmer once the bootloader is programmed.
    This way any serial device can be used. there is only one IF... If you dont need to change the config bits since they usually require a programmer.
    /me
    Nov 2007
    Thanks for your Jumper. Yes, a bootloader was my fallback option - just thought I'd check if someone had seen a "PDA" programming app first. But the more I think about it a bootloader might be better.
  1. Data Programming Error at 0000
    By cpatnoi in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2009, 04:37
  2. Problems programming
    By Lionheart in forum General
    Last Post: - 7th December 2008, 17:51
  3. Soic Icsp
    Last Post: - 13th September 2008, 20:51
  4. Replies: 1
    Last Post: - 11th December 2007, 00:57
  5. 16F819 ICSP programming
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 31st October 2004, 11:15
