12 bit or higher ADC on a PIC that works with PBP?
Results 1 to 9 of 9
    Brandon's Avatar
    Brandon Guest
    Question 12 bit or higher ADC on a PIC that works with PBP?
    Can someone list a few Pics that can do better then 10-bit ADC?
    I am using 16f88 Pics now to monitor two Pots (on different pins) using the ADC command at 10-bits.
    It's all great, (better then 8-bit) but I'd like something that can do 12-bit or better.
    I checked all the Pic chips and I just can't tell which ones will work with PBP and have 12-bit ADCs that work. For example the Pic16f882 looks to have 12-bit ADCs but in the datasheet it only talks about 10-bit ADCs.
    Thanks for any help,
    Brandon
    Feb 2003
    Salt Lake City, Utah USA
    go here http://melabs.picbasic.com/Scripts/p....pl?action=adv
    select 12 bits for the ADC resolution
    Your answer will appear.
    If you select the 16c774, make sure and read the errata. I used them years ago and they were not quite able to produce 12 bit resolution at the time ...
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Brandon's Avatar
    Brandon Guest
    Default Thank Paul...
    Thanks Paul,
    But I've used that utility, and one of the chips that comes up is the 16f882 as a 12-bit adc. But when I downloaded the datasheet for it, there is only mention of 10-bit ADC and 12-bit PWM.
    I know there are other Pics that the search comes up with. And I guess what I am asking for is one or two Pics that people know will work at 12-bit with PBP with no problems.
    Thanks again
    Brandon's Avatar
    Brandon Guest
    Talking Any first hand experience?
    Just to be really clear... I'm looking for actual Pic model numbers. Not just links to Microchips web site or big lists of chips.
    Anyone ever use a Pic with 12bit ADCs with PBP?
    What chip was it?
    How well did it work in 12bit?
    Sorry and welcome on the forum so far, but if you can't do a simple search for a part number, imagine how hard the coding will be... school work i guess?
    first hit
    PIC18F2423, PIC18F2523, PIC184423, PIC18F4523, datasheet : http://ww1.microchip.com/downloads/e...Doc/39755B.pdf
    it worked great
  1. decoding quadrature encoders
    By ice in forum mel PIC BASIC Pro
    Last Post: - 28th February 2017, 09:02
  2. AT/PS2 Keybord - PIC Interface?
    By Kamikaze47 in forum Code Examples
    Last Post: - 9th August 2009, 16:10
  3. Replies: 2
    Last Post: - 10th February 2006, 01:04
  4. PBP 16-bit ADC result math
    By sonic in forum mel PIC BASIC Pro
    Last Post: - 13th March 2005, 14:21
  5. Using PBP Hex Files with FED Pic Programmer
    By jrudd in forum mel PIC BASIC Pro
    Last Post: - 20th February 2005, 10:57
