Programer Error
Results 1 to 2 of 2
Thread: Programer Error
    Apr 2007
    Everett, Washington, USA
    Default Programer Error
    What would cause the error "Code programming error at 0000" ????
    I have the MELabs serial programmer and it only does it when I try to program a specific chip.
    Check your connections, and voltage on MCLR pin while programming. Depending how old your programmer is, you may need to do some modifications to. See the MElabs Website.,
    Could this also be caused by a not-loaded PGM pin ?
    Sure you'll find more info if you dare to search a little bit on this forum click here... at very least, have a look at the following old thread
    http://www.picbasic.co.uk/forum/showthread.php?t=1915
  1. Loop with two motor and 2 sensors
  2. Optimizing DIV
    Last Post: - 22nd September 2008, 04:58
  3. pbp245 compliation error
    By Woodzy in forum mel PIC BASIC Pro
    Last Post: - 25th July 2006, 05:59
  4. 16F88 Compile error
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 00:22
  5. Compiler/Assembler Error
    By LT_Pic in forum General
    Last Post: - 21st July 2005, 09:47
