Check your connections, and voltage on MCLR pin while programming. Depending how old your programmer is, you may need to do some modifications to. See the MElabs Website.,
Could this also be caused by a not-loaded PGM pin ?
Sure you'll find more info if you dare to search a little bit on this forum click here... at very least, have a look at the following old thread
http://www.picbasic.co.uk/forum/showthread.php?t=1915
