Pic12f615 Hpwm???
Results 1 to 12 of 12
    Apr 2007
    Everett, Washington, USA
    Default Pic12f615 Hpwm???
    I'm new at this and I'm totally confused.
    I have PBP 2.5 and Microcode Studio Plus. All I want to do for now is get an LED to fade on and then off again using the HPWM. I have looked at examples on the forum and tried everything I can think of with the different registers and all I'm getting when I compile is a long list of errors saying "Symbol not previously defined(register name)".
    The manual is no help and the datasheet doesn't do much better
    Can someone explain this so it makes sense???
    Probably because this pic don't have any built-in/Hardware PWM module (CCP)... to use HPWM you will need to switch to a 12F683, or use PWM, or create a timer interrupt.
    Apr 2007
    According to the datasheet it's on GPIO.2
    Place these defines in the top section of your code;
    DEFINE CCP1_REG GPIO
    DEFINE CCP1_BIT 2
    Should compile & work fine now.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Apr 2007
    It's still giving me a series of the same errors... I'm so confused!
    If you're using MPASMWIN as the assembler, make sure you have the latest version of
    MPLAB installed with the P12F615.INC header file.
    You could also try switching to PM as the assembler for a quick check.
    If you upgraded from an older version of PBP that may be a problem too if MCS is still using
    the old version at compile time. Support for the 12F615 was added in version 2.50.
    -Bruce
    tech at rentron.com
    oups, i think i didn't check the right datasheet...
    something is weird in the CCP1_REG and in CCP1_BIT declaration... So try to add the following defines
    DEFINE CCP1_REG GPIO 'Hpwm 1 pin port
    DEFINE CCP1_BIT 2 'Hpwm 1 pin bit
    EDIT: OUPS again... Bruce beat me. So now, what are those errors ??? Which version are you using?
    Apr 2007
    I have v. 2.5
    I must be missing something... Those defines look the same as the ones above????
    Error[113]c:\pbp\pbppic14.lib 1972 : Symbol not previously defined(registername)
    mmm, how about your code? so we can check it here as well.
    <hr>
    For the other members, you can fix this little problem and modify the 12F615.BAS file located in your PBP folder. Just open it and add the line in RED
    BANK0   $0040, $007F
    LIBRARY "PBPPIC14"
    DEFINE	CCP1_BIT 2
            include "PIC14EXT.BAS"
    PORTL   VAR     GPIO
    PORTH   VAR     GPIO
    TRISL   VAR     TRISIO
    TRISH   VAR     TRISIO
            include "PBPPIC14.RAM"
    '*-----------------------* EOF 12F615.BAS *---------------------*
    This will set the Default settings, and avoid to see that Warning [219] message again.
    Thanks Charles from Melabs!
    It doesn't explain error [113] of WireMan in the previous post... let's see it's code first
  1. need help on hpwm
    By helmut in forum mel PIC BASIC Pro
    Last Post: - 28th August 2007, 16:49
  2. HPWM of the port of two HPWM
    By ja2rqk in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 16:05
  3. HPWM down
    Last Post: - 10th January 2007, 01:06
  4. sound command & music
    By trying in forum mel PIC BASIC Pro
    Last Post: - 26th May 2006, 15:14
  5. 3 HPWM channels
    By docwisdom in forum mel PIC BASIC Pro
    Last Post: - 4th April 2006, 03:43
