Default microprocessor
Results 1 to 5 of 5
    May 2007
    Suffolk, UK
    Default Default microprocessor
    I have asked this question before - thought I'd cracked it - but haven't!!
    I am running MSPlus v 3.0.0.5 with PBPro v2.47
    When I open MS Plus on a new document it always defaults (in the target processor drop down box) to 16F628. I want to change this parameter to 16F877A. The help box in MCSP says there is a default.ini file in the main configuration folder to edit. The ONLY default.ini file I have on my computer is in Program Files\Mecanique\MCSP\EasyHID which only contains the following information:-
    [APPLICATION]
    HIDClean = 1
    [LANGUAGE]
    USBDevice = pbpgen.exe
    Host = bd5gen.exe
    I guess nothing here to edit.
    Querying this with Mecanique they said "you create the file yourself".
    I don't understand this.
    Can someone explain if I am in the right directory and right file and what I have to do to create the right worded file........
    adrian
    use notepad and create a Default.INI named file, then just write this simple line in
    16F877A
    and save it...
    not much.
    SWITZERLAND (french speaking)
    Great!
    But... where did you find this information?
    Roger
    in post #1
    i think it's already posted somewhere or i already messed with that years ago... i don't remind... sorry.
    May 2007
    Suffolk, UK
    Thank you Steve
    I created the file in Mecanique\MCSP
    Worked a treat! I'm a happy bunny now
    Adrian
  1. Other Microprocessor support?
    By rtsandiego in forum PBP Wish List
    Last Post: - 31st December 2009, 00:17
  2. changing code from 16F to 18F microprocessor
    By SCC_699 in forum mel PIC BASIC Pro
    Last Post: - 14th May 2008, 13:27
  3. Default thread age for FAQ's
    By JohnH in forum Forum Requests
    Last Post: - 8th October 2007, 02:11
  4. Default target processor
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 28th June 2007, 00:20
  5. Default settings
    By Archangel in forum Forum Requests
    Last Post: - 19th September 2006, 00:13
