Needing help with speeding up paralel port
Results 1 to 3 of 3
    May 2007
    Default Needing help with speeding up paralel port
    Hi!
    I'm using PIC16F88 eight digital outputs to drive DAC. Digital output change takes a lot of time as I have to change each of them. Is there any faster solution to change digital outputs in paralel?
    Simplified code:
    adval var byte 'input value
    b0 var adval.0 'first bit of input value
    b1 var adval.1 'second bit of input value
    b2 var adval.2 'third bit of input value
    b3 var adval.3 'etc.
    b4 var adval.4
    b5 var adval.5
    b6 var adval.6
    b7 var adval.7
    .... ' adval gets its value in a loop sequence.
    PORTB.1 = b0 ' PIC digital outputs gets its value
    PORTB.6 = b1
    PORTB.7 = b2
    PORTA.2 = b3
    PORTA.3 = b4
    PORTA.4 = b5
    PORTB.0 = b6
    PORTB.3 = b7
    With 4MHz oscillation the digital outputs set up time for 8 bits takes 32us.
    May 2007
    It went now to wrong thread. I'm using PICBASIC PRO. Maybe it can be moved under other topic.
    You can "put" a whole byte on a port by doing:
    PortB = ADVAL
    So the only thing I can think of is to change your hardware so that it "lines up" bit for bit.
    Or change your oscillator to 20Mhz.
    /Henrik Olsson.
  1. Why (or how to) make a port array for OW
    By Roy___ in forum mel PIC BASIC Pro
    Last Post: - 22nd February 2009, 23:30
    Last Post: - 14th November 2008, 17:25
  3. port config.
    By tamertokgoz in forum mel PIC BASIC Pro
    Last Post: - 25th July 2008, 12:25
  5. STATUS re-curtain W
    By zugvogel1 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2005, 15:21
