Table LED Matrix, Weeks of debugging, column problems
Results 1 to 28 of 28
    Sep 2007
    Update: I still have row 1 and column 1 on for testing. I removed one of the clusters in the first column and tried lowering the resistor values of 300 to 150, 47, and no resistors. The brightness obviously goes up as I go down in R, but even at no resistors the cluster is not as bright as an extra "test" cluster detached from the table and connected to a 9V battery.
    I used this extra cluster connected to a 9V battery for my intial table construction, as it was bright enough for the glass, and I assumed it would be getting 12V, so I knew for sure it would be sufficient.
    Any ideas?
    the plain fact is it is a matrix. in order to control each led without having a separate output for each led it needs to switch from row to row or col to col. in other words scan the matrix. if your seeing hy flash, then it is not scanning fast enough. by adjusting the scan rate and pulse width you can control the brightness. as loannis said it's doing what it's supposed to be doing. with a scope you can actually see the pulses and determine if they are too short or too far apart or anything else that is happening with them. if you just want them all on or off take out the pic and insert a switch.
    Default also
    you will never get the matrix as bright as your test cluster. to switch say 5 rows only one is on at a time. so each row is on only 20 percent of the time max.
    i'm not a C programmer but it looks like the line that says 4ms delay is your delay between rows. you could try making 259 a smaller number. i think that would get rid of your flicker but may make it even dimmer.
    Sep 2007
    Quote Originally Posted by nomad View Post
    There is no visible flicker in person. It only showed on the camera because of the fast framerate it captures at. The only problem is brightness.
    Update: I tried increasing the delay...that helped brightness a little but made the flicker noticeable to the human eye
    Yes, that's the price one has to pay, I 'm afraid. You cannot scan the matrix without a little flicker.
    On the other hand, you may increase the current that LED's draw. Do you have the data sheets about that LEDs? Are they capable to withstand more than 20mA?
    On a recent project I used Kingbright LED 5mm @ 20mA. They were really bright! They are 10000mcad and may replace car lamps (that's what I intend to do soon).
    Sep 2007
    Here you go! http://superbrightleds.com/specs/r3_specs.htm
    Looks like it's 50 mA, what would your solution be?
    Just connected to a 9V battery with the appropriate resistors they are too bright to look at directly. In my table, however, that is not the case :[ . There isn't any way to account for the scanning/duty cycle?
    Thanks to all of you for the help so far
    T.Jackson's Avatar
    T.Jackson Guest
    The faster the better is what I concluded with all the research I did in this area. Forget about any sort of delay on top of pulse width control. Just scan the thing like a bat out of hell.
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  3. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  4. LCD will not start
  5. 18F452 "Unknown Processor" errors
    By schwinn_rider in forum mel PIC BASIC Pro
    Last Post: - 27th April 2006, 04:56
